Old 09-11-2013, 09:58 AM   #1
Westward's Avatar
Coachwork: Ward Senator
Chassis: International 3900FC
Bathroom Dimensions
I am working on the layout for our bus and am looking at how much space to allow for the toilet room and the shower. We are going to have them split with the shower on the passenger side and the toilet on the driver side, but am not sure of the size to go with esp. for the water closet. (want to make sure there's enough space to take care of business and complete the paper work....without wasting space)
So as a help to those of us who are in the planning/building stages what bathroom set ups do the rest have? (combo, split, same side or opposite) And then the dimensions of the shower (including wall to run the plumbing in) and the interior dimensions of the WC?
Westward is offline   Reply With Quote
Old 09-15-2013, 05:20 PM   #2
bapos's Avatar
Chassis: 2001 International RE
Re: Bathroom Dimensions
Im curious as to what and how people are doing this also. I have the vision of a stand up shower with a toilet in it to compact space? Like everyone else I would love tons of room to shower and..well you know.... but we have such a limited space that you have to double up and make things as dual purpose as possible
Old 09-15-2013, 07:15 PM   #3
My toilet and sink are together, and across from them is the shower. The shower pan is 24in x 27in, a bit small but it works fine
The toilet faces the sink, its 33in wide by 41 long. Its a bit narrower at the sink. Ill post pics as soon as I can figure out my new I phone pics
Old 09-15-2013, 07:25 PM   #4
Elliot Naess's Avatar
Engine: 5,9 Cummins
Allow a good bit more room than you calculate you need. I find that people require extra elbow room to change clothes and such.
Elliot
Old 11-02-2013, 12:05 PM   #5
My planned bathroom is built more like a locker room shower. There is a lip at the entrance of the room to prevent water from escaping, and the whole room is effectively the shower area. The shower head is a bendy arm on the wall attached directly to the water heater (the bathroom shares a wall with the kitchen, letting them both use the heater directly with minimal plumbing)
AWebb3701 is offline   Reply With Quote
Old 11-03-2013, 03:22 PM   #6
Kathy WI's Avatar
I have a toilet room but not a shower. My toilet is a homemade composting one. I wanted to use the least amount of space as possible, so after measuring my toilet and my bod, I made the room 23" wide x 31" long. It's just barely big enough, a little more elbow room would be nice, so I'd recommend having the toilet centered in a space about 30" wide. I also didn't take into consideration that the guys in my family would be standing up to use the toilet, and the room isn't long enough to stand up with the door closed.
Kathy WI is offline   Reply With Quote
Old 11-05-2013, 01:32 AM   #7
Originally Posted by nat_ster
Strait from the water heater? No mixing with cold water?
I did say minimal
Old 11-05-2013, 11:34 AM   #8
syke's Avatar
Chassis: All American RE
We have an all in one bathroom. 3' x 10'. Shower is a 3x3 pan on one end of the room. Toilet is in the middle and full size vanity/sink on the opposite wall. All on the drivers side about mid ship. Bathroom door (swings out into the hallway) is basically in the middle of the 10' wall with plenty of room to close the door behind you. Shower is a little cramped in the head room department mainly because I'm 6 foot and the shower is up against an exterior curved wall. I wanted to make sure the bathroom was big enough for either the wife or I to take care of business without to much issue. With two of us living full time in the rig, we need things to work properly and to not be a burden. Living in a small space causes all sorts of sacrifices and one area I did not want to sacrifice to much was the bathroom. (gotta keep the misses happy)
Shower valve is on the same wall as the kitchen sink and water heater so that made for some really short pex plumbing lines. We also used mainly all home depot style fixtures and such. Basically in hopes that when something breaks I can fix it easily with household items and not expensive sub par rv style fixtures. Sounds good in theory at least.
Another item to think about is dumping the gray and black tanks. I kept all of our tanks on the drivers side in hopes that it would make using dump stations or hook ups at an rv park easier. So far it has worked out well but I do notice quite a few dump stations that would allow you to enter backwards and dump from the passenger side.
All just food for thought. No right or wrong way to go about it. Have fun though!
Ryan
Bluebird All American RE: Great White Buffalo (gone but not forgotten)
Our build thread: viewtopic.php?f=9&t=10065
syke is offline   Reply With Quote
Old 11-05-2013, 04:47 PM   #9
SeanF's Avatar
Chassis: IHC
Engine: Dt360
Rated Cap: 19
How do you keep from scalding your self?
Some water heaters have a set point for the outgoing water temperature. After some experimenting, I set mine to 107*F which allowed me to just turn on the hot water and not fiddle with blending hot & cold. Sometimes I would have liked hotter water for dishwashing, but it was a good compromise.
Bus conversion/info here
SeanF is offline   Reply With Quote
Old 11-05-2013, 05:17 PM   #10
Engine: 5,9 Cummins
You can also buy a valve that automatically mixes hot and cold to a set temperature. I have a Thermixer Tempering Valve by Symmons Industries. Just turn the knob to change the setting from 85 F to 160 F.
Elliot
bus dimensions? swinada Everything Else | General Skoolie Discussions 83 10-30-2018 01:28 PM
Interior Dimensions Seeria Conversion General Discussions 5 11-04-2009 07:43 PM
I need some shower advice! Post pictures of your bathroom! KC10Chief Conversion General Discussions 13 04-02-2007 05:19 AM
Year round bus conversion, bathroom, hitch and such update captainkf Conversion General Discussions 4 04-06-2005 01:58 PM
Dimensions Rose Conversion General Discussions 1 03-10-2004 10:09 AM
