Old 05-30-2018, 11:18 AM   #1
bidet and compost toliet
Hi all! I am trying to figure out how I can have both lol. Current plan is to make our own dry toilet and separate the urine. I saw on another thread someone set it up to catch the urine with a special attachment. Does it make sense that the water from the bidet would/could go into the urine separator? Also i need help own how to separate the solids and the liquids ...again the post I saw, they ordered something special on Ebay and of course it was sold. If water from bidet / some urine got into the toilet, adding more dry material should help correct? Thank you very much!
toomanydogs is offline   Reply With Quote
Old 05-30-2018, 11:30 AM   #2
Once the solids and liquids are mixed the compost will not work to contain the smell.
Old 05-30-2018, 12:44 PM   #3
brokedown's Avatar
100% a key part of the "dry" toilet is the "dry". Keep the liquids away from the solids (lots of threads about diverters), keep ventilation happening to remove moisture that is there (negative pressure ventilation ftw). Do't do things that make the compost wet or you will be a Sad Panda.
Follow us on Facebook, Instagram, and Twitter
brokedown is online now   Reply With Quote
Old 05-30-2018, 01:48 PM   #4
Okay thanks for the replies!
Old 05-30-2018, 01:58 PM   #5
Dry toilet is the key terminology.
No one is leaving their turds in them plastic bins long enough to actually turn to compost.
Bidet is a good thing!
I mean- if poop were on any part of someone other than their butt I bet they'd use more than just TP to clean it off!
Roll Your Own Build Thread
Old 06-07-2018, 11:16 PM   #6
Ninjakitty's Avatar
Engine: 6.6 New Holland Dies
Rated Cap: 60 kids, 10 window
Your looking for a "urine diverter".
Nick
Old 06-09-2018, 09:48 PM   #7
turf's Avatar
waterless bidet?....i think i've seen something like that before...
where i come from, we call it toilet paper.
Turfmobile Build Thread
Old 06-09-2018, 11:26 PM   #8
If you really want to get back the composting idea, use a fig leaf.
1olfart is offline   Reply With Quote
Old 09-13-2018, 03:23 PM   #9
Paulymac's Avatar
Engine: T444E 7.3 L
Rated Cap: 62
Good ol' magnolia leaf has a velvet underside.......very nice!
Paulymac is offline   Reply With Quote
Old 09-13-2018, 11:22 PM   #10
May be out of the question, but what size bus do you have? Is ther enough space to have a wet, and a dry setup? The wet toilet could even be a little smaller than the dry. Depending on size, it may even need to be emptied more often than the dry, but it could be done.
If you do, do a bi9det, be sure to let us know how you plumbed the squitter.
BTW, sorry the fig leaf idea didn't do it for you.
