Old 07-06-2015, 06:45 PM   #21
Originally Posted by gbstewart View Post
I would really try to put your toilet right above the black tank, nice straight drop, no bends or twists to have a clog. also easier to install.
Thanks for the visual
Old 07-06-2015, 09:27 PM   #22
But I thought the healthy turds were suppose to have bends & turns and that those with a problem came out straight like a log.
The-Breeze is offline   Reply With Quote
Old 07-07-2015, 06:34 AM   #23
boy did this thread take a twist lol
Old 07-07-2015, 08:22 AM   #24
M1031A1's Avatar
Chassis: Saf-T-Liner ER
Engine: 3208 CAT/MT643 tranny
Rated Cap: 87
Three letters: TMI Need I say more? LOL
M1031A1 is offline   Reply With Quote
Old 07-07-2015, 04:08 PM   #25
Ya...your toilet should mount so that it drops straight down into the holding tank.
Old 07-07-2015, 11:51 PM   #26
Hubby & I talked about it some more and with the Jabsco marine crapper we felt y'all were right....so it's straight down from here (the only thing curly will be --->well you know, what Dr Oz said, curly is good).
We're new to this HepVo valve so I told Hubby I thought that with that design we shouldn't be getting any fumes from the black/grey tank in the kitchen sink. Anyone have any experience with that?
We're gonna go for it and worry about putting in an extra tank if need to later down the road and water in the sink until then.
As for a macerator...he feels that the hand pump acts as it's own macerator so we shouldn't have a need.
Old 07-08-2015, 07:06 AM   #27
forgot to answer about tank size I have a 40gal black and 40gal grey.
Old 07-08-2015, 07:13 AM   #28
austin1989us's Avatar
Chassis: TC/2000
Engine: Cummins 5.9TA
How much poop fits in a 40 gallon black tank? I guess the better question would be, how long does it take to make 40 gallons of poop? Is it full after a week? A month? idk how big of a tank will work for my bus.
austin1989us is offline   Reply With Quote
Old 07-08-2015, 04:53 PM   #29
it really depends, how many people and how much water. with me and my wife and daughter we can go up to 2 weeks,if real careful,and I pee on a tree or the tires we can go maybe 3 weeks, put thats pushing it, you have to keep in mind you have to use a certain amount of water, otherwise your tank can dry up and leave you with a solid mess in the tank, theres also the smell factor, it could get a bit ripe. you can use chemicals for that, also I think your toilet needs a bit more water so it can grind properly (I think). the grey tank will fill alot faster, depending how many showers, dishes, etc.
Old 07-08-2015, 05:22 PM   #30
all of it, I'd hope
Old 07-08-2015, 05:31 PM   #31
LOL 40 gallons of poop.
Old 07-08-2015, 06:38 PM   #32
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
Originally Posted by milkmania View Post
all of it, I'd hope
Old 07-08-2015, 08:02 PM   #33
this never gets old lol
Old 07-08-2015, 08:31 PM   #34
Old 07-08-2015, 09:06 PM   #35
REDD's Avatar
Coachwork: Thomsass
Chassis: FreightShaker
Engine: 5.9 Cummins 5 speed
Rated Cap: 2 ATV's and friends
This s#!t's funny.
Old 08-07-2015, 04:57 PM   #36
Originally Posted by allwthrrider View Post
Decided to go with one of these fuel tanks off another Crown that was crushed, capacity is 112 gallons, mounted upside down with a macerating pump off the filler neck , question is can I use the sending unit as level sender to a fuel gage or will the waste just corrode it real quick ?
Well I'm in the process of relocating my fuel tank so I could mount one of these tanks for a combination Grey & Black tank, it's 112 gallons but made of steel, I just read an artical about a street light that fell in San Francisco because so many people & dogs urinated on it made it corrode to the point it collapsed,
Question is if I go ahead with my plan will the bottom fall out in just a few years?
Old 08-07-2015, 05:39 PM   #37
Urine is highly corrosive. Plastic is used for holding tanks for good reason.
Old 08-07-2015, 06:02 PM   #38
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Have you ever looked at the urinal dividers in a public bathroom. You would think they were made from body panels from rust salt belt vehicles.
I'm hungry!
You Gotta Let Me Fly
Old 08-09-2015, 04:04 PM   #39
Chassis: Blue Bird
Engine: ISC 8.3
And.. one hopes.... that's the effect just from occasional splashes, not frequent direct spray!
Old 09-29-2015, 11:13 AM   #40
I'm starting the installation of my waste tanks, I'm installing a 112 gal fuel tank thats been boiled out for my grey tank & I've just ordered a 40 gal black tank on ebay, I'm going to install a macerating toilet then also have a macerating pump off the black tank but want to install a shut off valve before the pump inlet, I'm thinking this valve & it has a NBR diaphram & I'm wondering if human waste would be damaging to it.
http://www.amazon.com/gp/product/B00...23860_70668520
Stuart
Need thru tank fittings!! for black water tanks ddpartybus Conversion General Discussions 5 04-18-2015 02:56 PM
Black/Gray Tank Vent kamoo Plumbing, Water and Waste 9 06-24-2009 09:29 PM
Black water/ Gray water tank travlenhippie Plumbing, Water and Waste 3 10-21-2008 08:53 PM
Gray and black vent pipes oldog12 Plumbing, Water and Waste 17 10-14-2006 12:08 AM
Black/Gray Tanks - need both? vonslatt Conversion General Discussions 5 04-03-2005 09:16 PM
