Old 10-25-2011, 08:25 PM   #1
Engine: DTA360
Rated Cap: 16
Black tank question???
Has anyone had any luck moving the toilet flange input on a tank??? If so, what did you use to seal it and how did it work out???
I've got a tank that will fit perfectly under the bus but need to move where the toilet input is...
dirtygoat is offline   Reply With Quote
Old 10-25-2011, 09:00 PM   #2
wtd
wtd's Avatar
Year: 1982
Coachwork: Thomas TransitLiner
Re: Black tank question???
Mine was an ABS tank, just a square plastic box with an outlet port, had to cut your own holes.
Naturally I punched a hole in the wrong place for the shower drain
Epoxy painted a piece of 1/2" plywood, RTV'd around the 'bad' hole, laid the plywood over it and screwed it down with a drywall screw in each corner, silicone caulked around the edge of the plywood and was a little more careful with the new hole ...
No leaks in 6 years.
If yours is an ABS tank, seems like the same thing, only a bigger hole.
The Rolling Motel Room
Where DIY meets WTF
wtd is offline   Reply With Quote
Old 10-25-2011, 09:02 PM   #3
Engine: DTA360
Rated Cap: 16
Mine is out of an old camp trailer... Don't think it's asb...
Old 10-25-2011, 09:03 PM   #4
bus-bro's Avatar
Engine: 3208 na boat anchor
Maybe something like this: http://www.tank-depot.com/product.aspx?id=161
Old 10-26-2011, 12:31 AM   #5
lornaschinske's Avatar
Rated Cap: 89
If it's out of an old RV, chances are it's Poly. PITA to patch. I've heard they do make a glue for it. New just out this year or last year. Haven't seen any yet. How much do you need to move the toilet? If just a little, you might get away with using a 45 degree pipe. Otherwise, buy a new tank. Get ABS so that you can patch it!
Fulltime since 2006
Old 10-27-2011, 12:59 PM   #6
Engine: DTA360
Rated Cap: 16
It's kinda a cream color on the inside with little black speckles...
Black Tank question SitkaConvert Conversion General Discussions 4 09-23-2014 03:51 PM
Black tank dump valve syke Conversion General Discussions 7 09-12-2011 04:55 PM
One Tank or Two? (Grey/Black) Hex Plumbing, Water and Waste 13 06-29-2011 06:30 PM
Fuel tank for black water bluebird90 Conversion General Discussions 13 04-14-2011 07:21 PM
black water tank and a door sportyrick Classifieds | Buy, Sell, Swap 16 04-19-2008 11:39 PM
