Old 07-26-2018, 01:08 PM   #1
OrionsComfortBus's Avatar
Coachwork: International - AmTran
Engine: DTA 360
Rated Cap: 25,500 lbs
Broken windshield washer connector
While I was swapping out the upper light lenses (red-back, amber-front) I seen the washer nozzle needed to be clipped back onto the wiper arm. I guess I flexed the old connector too much and SNAP! This one passes through the metal beneath the wiper arm. How do I access that spot to install a new one?
On another lo/high note, My steering wheel horn button was taken loose but the fastening hardware was lost. anybody know the screw type/size? Threads per inch? Length?
I'm going to visit a parts/junk yard that has a few buses. Might find some useful stuff there.
OrionsComfortBus is offline   Reply With Quote
Old 07-26-2018, 01:53 PM   #2
Where are you at? Where is this salvage yard and name. See if they have a flat International back door. Fill out your profile (UserCP)so we know where your at and what you're working on.
Old 07-26-2018, 03:56 PM   #3
Engine: DTA 360
Fill out user cp. Done.
Name of junkyard. Unknown. Seen it as I drove by.
The price of freedom is eternal vigilance. - Thomas Jefferson
Ongoing project of maintenance and replacement of things in and on the Comfort Bus https://www.skoolie.net/forums/f9/up...bus-24772.html
Old 07-26-2018, 04:01 PM   #4
Now that you've filled out your profile it makes it easy for me. I see now you have an International like mine and that you are probably too far away to help me with a door from there. But if you go there and they do have one, for sure let me know.
Old 07-26-2018, 04:10 PM   #5
Engine: DTA 360
Absolutely! I'll include all the information so you can contact them.
Old 07-26-2018, 04:12 PM   #6
Is your rear door the same as mine" It's flat and 53.25" x 37", upper and lower glass?
Old 07-26-2018, 07:36 PM   #7
Coachwork: integral
Rated Cap: 37,400 lbs GVWR
When I replaced my entire washer system I changed out all the through-cowl connectors to angled ones sold for Thomas buses. They accept larger tubing than the miserable little tubing that was originally there, so along with new Blue Bird adjustable nozzles and new electric pumps I now have a veritable Niagara on my windshields when I push the washer knob. Yeah! It's much better than the original Sprague air-powered washer that would ejaculate dribbles of water onto my foot while driving.
And if you're wondering how to access them, you just have to become a contortionist able to shrink your arm to half its size and bend in three extra places, then it's easy.
Old 07-27-2018, 01:03 PM   #8
Engine: DTA 360
re: International bus
I stopped by the place where I seen the used buses. All they had we're flat nose Bluebird's. I'll keep looking for bus junkyards around here. Otherwise I'd suggest used bus sellers who buy from auctions. They might have a few parts buses.
Old 08-03-2018, 04:08 PM   #9
golfersmurf57's Avatar
My 92 TC2000RE HAS DOORS that you open under the outside windshield. If I need em I'm going plastic #4 sae bulkhead fittings then adapt outer to barbed hose fittings.
golfersmurf57 is offline   Reply With Quote
