Old 11-07-2009, 10:40 AM   #1
Seeria's Avatar
Building your own shower stall?
I noticed a few folks built their own, which might be what I need to do since the cost of buying a shower stall is not on my budget this year.
Any chance there is a guide to materials that can be used? Walking around Menards and Lowes all I found were kits ($200plus, most $300 plus).
Old 11-07-2009, 05:54 PM   #2
TygerCub's Avatar
Engine: Detroit
Re: Building your own shower stall?
If you are looking for inexpensive, but durable, waterproof, and strong, I say go for corregated roofing framed out with wood.
If you use the metal kind, you can bend each sheet in the middle to create the corners, overlap them in the middle of each wall, just as you would on a roof, and ensure a watertight seam with caulk/construction adhesive in the overlap joint. For the fiberglass kind, just cut a 3" PVC pipe in half, put it in the corner so each wall is cradled in the curve, and caulk.
For the tub, use a mortor mixing bucket. I have a 2' x 3' that I hope to use for this purpose, but they do come a little larger than that. Look in the cement section of Lowes or your local big-box home improvement store.
You can be as cheap (3 shower curtains on rods), or as expensive as you can afford (completely tiled stall). Just up to your imagination and pocketbook!
Old 11-08-2009, 10:05 AM   #3
Seeria's Avatar
Thanks folks!
Cheap is good, waterproof is better. Reading these post, have to say I like the idea of making my own because I can design to handle the needs of disabled family members. Will do some salvage yard and big toy store (menards, lowes here) window shopping, see what I can find.
Old 11-08-2009, 10:37 AM   #4
Marlite is not waterproof, don't use it for a shower or you will be replacing it. Lowes and Home Depot have white 4'x8' sheets of plastic for sale pretty cheap. You can also use latex caulking or latex/silicon caulking for glue as it doesn't leave an indentation (melt) in some plastic sheets the way liquid nails sometimes does.
Abbott is offline   Reply With Quote
Old 11-08-2009, 06:04 PM   #5
Year: 85
Coachwork: Ward
Chassis: G.M.C. 6000 series
Engine: 366 G.M.
Rated Cap: 60
I put my toilet in one end of a fiberglass tub using the tub as a tray . With the holding tank mounted under the tub, cutting a hole in the tub then the floor was no problem, I just made sure that any wood that was exposed was fiberglassed over to keep out any water that it mite come in contact with. 3M 5200 is your friend can be found at any marine supply. Now I s--- shower and shave in the same place without moving. Life is good. I've been cutin and glue'n pipe all day,do'in the plumbing thing.
Russell is offline   Reply With Quote
Old 11-08-2009, 08:18 PM   #6
GoneCamping's Avatar
You can find very affordable shower base and RV bath tubs on ebay from a seller called Tri-State Surplus, I got mine from them and paid only $32 for the shower base. I built the walls out of various materials, had some brand new shower walls that someone discarded and I took them, made the 3rd wall from that "Sani-Lite" (it's what they call it around here) material I got at Lowes (fiberglass reinforced plastic panels, bumpy on one side and smooth on the other).... I highly recommend Tri-State Surplus, they have the best prices ANYWHERE and she ships fast too!!
*Cliff*
...Your home has brake lights
1994 Jeep Grand Cherokee
Chesapeake, Virginia
GoneCamping is offline   Reply With Quote
Old 11-09-2009, 10:01 AM   #7
Originally Posted by Smitty
While the term "Marlite" is a general term, like "paneling", it (specifically Marlite) was and still is infact used for showers. I've used it myself in more than 1 shower, and each lasted for atleast a decade. If the OP were to build a shower using it, it would likely outlive the bus, as long as it was properly installed & maintained. Nobody was talking a $500,000 show home here
Smitty
I have torn out several showers that were built with Marlite and replaced them with the proper product. Marlite is Masonite with a plasticized coating which does not cover the edges of the board. When water is leeched into these edges the layers of the Masonite separate and deteriorate. The plasticized coating will also discolor as it begins to separate from the rest of the boards layers. Marlite was designed to be used "near" wet applications such as bathroom and kitchen walls etc. Marlite was never intended to be used "in" a wet application such as showers although some folks have done so because it was a cheap product and readily available. Using Marlite for a shower application to save money is obsolete, plastic sheets are a much better alternative and have become readily available and affordable. 4'x8' white plastic sheets can be found pretty cheap in the paneling department at Lowes and Home Depot.
Old 11-09-2009, 03:03 PM   #8
Ob1
Year: 1963
Coachwork: Grumman
Chassis: Chevrolet
Engine: Chevy 292 I-6
One of the conversions in the gallery shows a guy using a stainless steel sink as a shower base. Looked especially cool when you take into account that with the bowl recessed into the floor, head room grew about 8 inches, sure wish I had that in mine!
Ob1 is offline   Reply With Quote
Old 11-09-2009, 04:27 PM   #9
Griff's Avatar
Year: 1982
Chassis: IH S1723
Engine: IH V345 Gas V8
Originally Posted by Ob1
One of the conversions in the gallery shows a guy using a stainless steel sink as a shower base...
That would be Andy-B-Bus-9: http://www.skoolie.net/gallery2/v/Sk.../Andy-B-Bus-9/
Griff is offline   Reply With Quote
Old 11-09-2009, 06:00 PM   #10
Seeria's Avatar
Hey Cliff, can you toss me a link to this tri state seller, please? My searches on ebay bring up nothing.
can you cut down a shower stall? Jaybus Conversion Tutorials and How-to's 10 01-28-2015 01:23 PM
SHOWER STALL BUILD timbuk Plumbing, Water and Waste 11 01-09-2010 11:59 PM
Building a black water tank and shower base. smitty500 Conversion Tutorials and How-to's 3 09-09-2009 04:49 PM
shower pan GoneCamping Conversion General Discussions 1 06-24-2007 06:45 AM
Shower Stalls, Shower Stall Pans Ryan Grimm Conversion General Discussions 6 05-18-2006 03:57 AM
