Old 10-02-2017, 07:57 PM   #41
Years ago i drove a 51 Chevy 2 ton truck that had a 2000 gallon tank with diesel in it.1 st time!! Dumb kid i was charged up to the turn in the driveway. I turned and it went up on 3 wheels on the drivers side. Didn't turn over but scared me real good and you should have seen the face on my boss that was right behind me.
Old 10-02-2017, 08:00 PM   #42
Since you are a Newbie i think to advise you that you don't drive a bus the same as a car. Just a hump in the road for a car is like a jump off a ramp at times for a bus. You can bounce everyone off the roof very easily.
Ask us lots of question and read all the posts you can. Welcome.
Old 10-02-2017, 08:11 PM   #43
I like versatility. I am using a TRANSFER PUMP. With my pump i have water in the bus, i can fill my tank from a well or spring and it will lift it 15 ft at the inlet. Much more on outlet side. I tank use the pump and pump from a well etc and then directly into a horse trough etc. or to have water for whatever reason.
Old 10-03-2017, 12:56 PM   #44
Engine: 466DT
Originally Posted by bertoliann View Post
Where do you even get pvc pipe that big? We looked at Menards and the biggest they had was 6 inch
Sent from my SM-G950U using Tapatalk
You will have to try and find a Utility Supply type store in your area (not box store) Or a plumbing supply business.
The bigger 8" and up is used in city infrastructure, or commercial buildings, not really residential.
Hvbuzz is offline   Reply With Quote
Old 10-03-2017, 01:50 PM   #45
mmoore6856's Avatar
Chassis: chevy
Engine: 3116 catapillar
That was back in the "hold my beer and watch this" days
mmoore6856 is offline   Reply With Quote
Old 10-08-2017, 08:11 AM   #46
PUCKER FACTOR !!!!!!!!!!!!!!!!!!!!!!!!!
