Old 04-19-2016, 02:15 PM   #21
Originally Posted by Tango View Post
Less space taken up by tanks, but not necessarily less problems. As noted above, the most common black/gray dump procedure is to dump the black then use the gray water to rinse out the black tank. When combining the two into one tank, you will still need some method of rinsing the black/gray combination. If you are using a conventional RV flushing toilet, invest in a rinse wand that can be hooked to a hose and poked down the toilet to clear any leftover nasty stuff from the tank. It almost never all leaves of it's own accord.
Reason #32 to consider a composting toilet IMHO.
Old 04-19-2016, 02:47 PM   #22
Engine: 5.9 Cummins, Allison 545
i used a single tank on my bus.
from previous campers, i've never dumped my grey tank into anything other than a sanitary dump, so i didn't see the purpose of two tanks.
traveling, i tend to just use the toilet. no dishes, no showers. with one tank, i have had the problem of clearing solids. but only when i have used very little grey water.
now, on the way to the dump station,i'll turn on the faucets and try and drain the fresh water tank into the holding tank to help clear out the log jam.
seems ok by me.
if my system were to back up, it would back into the shower. But, i used hepvo valves on both the shower and sink. they are one way valves that i doubt would fail that easily. So, i suspect if it backed up, it would back up all the way to the vent before anywhere else.
also a good idea for the dump tank to be a bit bigger than your total water carrying capacity..... lots less chance for messes.
Turfmobile Build Thread
Old 04-19-2016, 03:26 PM   #23
Robin97396's Avatar
Chassis: TC 1000
Engine: 5.9
Send a message via Yahoo to Robin97396
Turf, my thoughts exactly. The only advantage to two tanks is the ability to rinse the black tank with a rush of grey water. If your tank is designed with a sloaping floor toward the drain it should clean out pretty good anyway.
I used to flush a black tank, then put in a couple inches of clean water so it sloshes around and cleans itself up while traveling. Besides, after draining your black tank you probably shouldn't let it dry out from lack of use while there are remaining solids.
Old 04-19-2016, 05:35 PM   #24
Another trick for cleaning the solids out of a black tank is to put a couple of bags of ice down the toilet and then drive to your next campground....The ice with the motion of sloshing around in there will loosen the hard stuff.....Dump as soon as you get to your next dump station.
poncho62 is offline   Reply With Quote
Old 04-19-2016, 06:11 PM   #25
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
On my first ship, USS Will Rogers, every quarter, the A-gangers would suit up and mask up and actually dive the sanitary tanks to clean out the Klingons with a fire hose that were not normally eliminated due to the utmost stealth reasons.
Mind, the sanitary tanks on submarines are CONSIDERABLY larger than that found on RVs. That, and 250 men are a bit more in number than those who use an RV. But there will ALWAYS be Klingons who have evaded the Federation by one means or another.
Unless you plan on installing a wash-down system within the tanks, keep black and grey separate.
Old 04-19-2016, 08:34 PM   #26
I have black and grey tanks, i'm not really sure I would want just a black tank, I have had my grey tank fill up more then once when having a shower where the water would flow around my feet, don't need the black tank running between my toes.
Old 04-19-2016, 08:41 PM   #27
Robin97396's Avatar
Chassis: TC 1000
Engine: 5.9
That is an excellent point gbstewart.
Here's a dumb question. Is there actually some special place where people dump grey tanks separately from black tanks? Is it inappropriate to dump both when you're at a RV dumping station? I must have been doing it wrong in the past.
Old 04-19-2016, 08:59 PM   #28
Nothing wrong with dumping both at a dump station...The point that was being made was that there are places you are allowed to dump grey water, but black water MUST go into a dump station
Old 04-19-2016, 09:00 PM   #29
jester's Avatar
Chassis: RE200
Engine: 7.3L Navistar T444E
no, no, they both get dumped in same place at the rv parks. the grey could be "illegally" dumped just about anywhere because its just water and lil soap.
i carry 92 gallons fresh h2o and will have 100 gallon tank with alarms i will install, so for boondocking theres not enough h2o onboard to overfill the tank = win. when in rv park, i will only let tank get half full ~ 2/3 full before i dump it, same as you would with grey and black tanks ran separately.
on side note, any one ever sprayed inside of tank with Never Wet or some one of these super hydrophobic sprays we've got now? ive seen cement slide free of a shovel coated with it, leaving the shovel clean.
check out my build pics
http://www.skoolie.net/forums/member...albums833.html
or my random writings... at
www.roadrunnerlogik.blogspot.com
jester is offline   Reply With Quote
Old 04-19-2016, 09:03 PM   #30
it all goes into the same hole, when you pull up to dump your tanks, you put your 3inch stinky slinky hose it the hole, dump black first, close the valve, dump grey tank, this flushes the hose out , eazy peezy done it 100 times or so. when boon docking I have dumped some grey water into a pale and used it to water the bushes , giving me some extra time , black tank takes a while to fill .
