Originally Posted by AvoCadOH_family
i'm following this. i had this exact idea because my hubby is 6 ft tall and i'd like for him to be able to shower standing up. I'd also love to be able to take a bath so a horse trough has definitely been on my "watching for" list.
I'm doing the same thing but with this step tub:
https://www.campingworld.com/sit-in-...ite-68807.html projecting below the floor. If you can weld and have access to some reasonably-priced scrap metal, it's pretty easy and cheap to do on a school bus. One caveat is that to have an all-gravity-fed drainage system into a gray water tank, your clearance is fairly tight. I don't want my gray tank to be sticking below the side skirt, so I'm restricted to a flat 9" tank and a hepvo valve, which is a horizontal alternative to a p-trap.
However, you can also install a system where the dropped shower drains into a small temporary tank, from where it's pumped uphill into a higher-mounted gray tank. I didn't opt for this because I want my setup to be as simple and cheap as possible.
Edit: just realized I said basically the same thing two posts earlier. Ah well ...
