Originally Posted by bigskypc50
So all of my dumps and water and electric hooks up are in the left (drivers side) very rear. You can put your tank anywhere you want just as long as you can plumb a 3" drain line at the right angle with a gate valve, you should be golden.
You can also just snake the slinky under the bus to the other side....that's what I do with my greywater. I'm not sure if that would work with a black tank though, since we don't have one. I pulled the wrong way into an ambidextrous one and got shamed by someone that pulled in from the other direction.
