Old 03-30-2019, 11:40 AM   #1
farok's Avatar
Engine: 6.0L Gasser
Excel water heater gas pressure?
Has anyone seen what pressure the propane needs to be for the Excel tankless ventless water heaters? I'm wondering if the same regulator can be used for that and the stove I'm looking at, which requires 11-14" WC. Figured I'd check with this crowd before trying to reach the manufacturer. Thanks!
Chris
My build thread: https://www.skoolie.net/forums/f27/fi...ild-25804.html
farok is offline   Reply With Quote
Old 03-30-2019, 11:59 AM   #2
They run off 11"wc
Old 03-30-2019, 12:36 PM   #3
farok's Avatar
Engine: 6.0L Gasser
Great. Thanks!
Old 03-30-2019, 02:04 PM   #4
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
If using one regulator for two appliances I would recommend making a bigger line size manifold/header to create better volume for when both appliances are working at the same time.
Old 03-30-2019, 08:57 PM   #5
farok's Avatar
Engine: 6.0L Gasser
Good point. I don't anticipate them both working at once, but just in case, it wouldn't hurt. Thanks!
