Why does the vent have to go all the way to the roof? Can you have a 90 degree bend in the vent? Why can't the vent just stop underneath the bus?
My understanding is that the height you can fill your tank to is limited by the height of where your waste intake is. Yes, you could put it in the side, but then you're losing the top 1-4" of fill-height inside your tank. I'm sure if I'm not correct, someone here will chime in and tell you so.
