Old 05-08-2017, 02:12 PM   #1
wendysdrivethrudude's Avatar
Grey Tank Troubles
I've looked forever for water tanks and I managed to find a 95 gallon freshwater tank for almost half the price of what similar tanks go for.
95 Gallon RV Water Tank W-214
However, I can't find a similarly priced grey water tank, so I am considering having the company put custom fittings on the freshwater tank to make it function like a grey tank. Can I do this, and if so, how should I? It will be placed on the driver's side in front of the wheel well and sunken shower and a washer/dryer combo unit, two sinks, and the shower will drain to it.
The Endeavor Build Thread
wendysdrivethrudude is offline   Reply With Quote
Old 05-08-2017, 02:53 PM   #2
Find another tank for grey water, don't cut up a perfectly good fresh water tank.
Anything will do that has an adaptable inlet and outlet. I made one from a plastic gas tank off a wreck.
Old 05-08-2017, 04:06 PM   #3
My father has a bunch of junk buses that are only used for parts. Could I use a fuel tank off one of them?
Old 05-08-2017, 04:17 PM   #4
Robin97396's Avatar
I think you'd have to ask your dad, but it's probably ok with the rest of us.
Robin
Nobody's Business
Old 05-08-2017, 04:26 PM   #5
Njsurf73's Avatar
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
Well, I was going to suggest you find a junk/salvage yard and hunt out something close. But having. Bus graveyard at your disposal is a step up.
Old 05-08-2017, 05:44 PM   #6
If he has one from a bus that had a gas engine I would say go ahead. One from a diesel will be pretty contaminated and the residue will last a long time unless you can clean it out somehow. Lucky you with a boneyard so close to home.
Old 05-08-2017, 06:24 PM   #7
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
I'm using a 110 gal tank from a junk bus for my grey then I took another one cut it in half welded on a 1/4 in plate & using it for my black tank.
Old 05-08-2017, 06:25 PM   #8
Black tank
Old 05-08-2017, 09:07 PM   #9
S&F, I see you installed a macerator on your black tank. I did the same--best thing since fried bacon in my opinion. No more stinky slinky, just a short run of 5/8" garden hose.
Old 05-08-2017, 09:35 PM   #10
Yes ol trunt I'm also using a macerator toilet to pre grind the waste plus I'm using one to pump grey into the black, I'll also be using a 1in hose so by the time I dump things should flow fairly easy. ( I hope)
Old 05-08-2017, 09:59 PM   #11
S&F and others. I made a little adapter plate that allows me to direct fit the 5/8 " hose to the "normal" sewer hook up at RV campsites etc. When it is time to dump my tank I just flip a switch inside the bus and all is done automatically.
While this is going on I just sit and think about how smart I am--I know, I know, one day the macerator will quit and I'll be in s#%t city. Oh well, I've been there before!
Old 05-09-2017, 01:21 PM   #12
My father is a farmer, and buses are very versatile in that particular profession. He uses them to transport migrant workers, cuts off the tops to haul watermelons, and modifies them into specialized vehicles like fertilizer spreader trucks and goats (which get oranges from the picking tubs into trailers). My grandfather likes to buy engine-less buses, stick a hitch on the front, and turn them into trailers.
All my father's buses are diesel, so if I used a gas tank I'd have to look elsewhere.
Old 05-09-2017, 01:58 PM   #13
LOL thats why I have a default to close dc powered valve between the tank & pump
Old 05-09-2017, 02:28 PM   #14
Coachwork: 2003 Thomas E-350 shorty
Chassis: E350
Engine: 7.3 Powerstroke
Rated Cap: 24
Seems using a fuel tank for water waste is begging for rust problems....I'd hate to be behind the bus when the $#!t hits the road!
If it isn't grown, it has to be mined
elkoskoolie is offline   Reply With Quote
Old 05-09-2017, 04:16 PM   #15
I have to agree with you but not all tanks are metal. Myself, I have a really tough plastic gas tank and mounted up behind the rear left mudflap area, so it's pretty much protected. If those tires on that side happen to blow, I may get lucky, if they do and the worse happens, I don't really give a chit. That's what car washes are for but the chances of anyone being on my tail that close is slim.
Old 05-09-2017, 04:28 PM   #16
Yea but with soaps / shampoos coating the inside & as thick as this tank is it will proably last a good 30 yrs, These tanks came out of a another Crown bus & Crown didn't use cages around their tanks, this thing is a beast. MHOP.
Old 05-09-2017, 04:39 PM   #17
If I can't manage to find a tank of the appropriate size/shape/material/price/whatever, could I use two tanks and create some sort of split system and have two dump pipes that join at a single dump valve?
Old 05-09-2017, 05:34 PM   #18
Your plan sounds feasible if you can lay it out right and have some fall in the discharge pipe for good drainage. I would build it so that the grey tank could be used to flush the lines after the honey tank is dumped. Then if you have to ever take it apart it will be a whole lot cleaner than the other way.
My 2 cents anyway.
Old 05-11-2017, 11:49 AM   #19
I'm going to go to a tank company my father does business with and look at what tanks they have available. If I can't find something I like within a reasonable price range I have a backup plan.
The translucent tank was used as an extra water source at the track back when my father and his brothers drag raced. They finally figured out how expensive and dangerous it was, and sold everything but this tank. I've gotten the okay from them to use it in the bus if I can't find a better solution. It holds 55 gallons and has a gate valve for dumping, with a large black cap on the top for filling it and probably for easily cleaning it out.
The black plastic barrel was filled with some nasty green chemical probably used in the groves. Some of the liquid was still in it, which I was sure to be careful with and thoroughly rinse in case it was acid (I've had two bad run-ins with acids and I don't want to have a third). It holds 30 gallons and has two bungs in the top.
Having the two tanks dump from the same valve would be simple enough. Having them both fill at a relatively even rate is something I'd have to put more thought into. Maybe I could have the sinks drain to the small barrel and the shower and washer/dryer drain to the large tank, or figure out some way to make them both fill evenly. I don't know. I'll try to hit up the container company tomorrow and see what they have laying around. Let me know what you guys think.
Old 05-11-2017, 11:50 AM   #20
Here are the tanks
