Old 06-22-2020, 12:25 PM   #21
Coachwork: Amtran RE
Chassis: International 3000
Engine: T444e 7.3L
Perhaps a stronger way might be to drill completely through the square tub and insert a sleeve so that a bolt and nut could be used. Water is very heavy and moving water (sloshing) acts even "heavier" and I'd be concerned about a rivet being strong enough--especially an aluminum rivet.
Aluminum would also cause corrosion.
Biscuitsjam is offline   Reply With Quote
Old 06-22-2020, 12:34 PM   #22
Chassis: TC RE
Engine: 8.3 Cummins MD3060
Originally Posted by WIbluebird View Post
For people with factory understorage, did you put the tanks directly on the bay floors? Mine look pretty decent/strong but I've seen other people with rusty pushers where the cargo bay floor just fell apart.
I may have to rig up a system where the weight of the tanks is shared between the floor beams and the cargo bay floor.
How does one go about determining if the floor of the bay is going to be strong enough? If it's laying flat on the floor, it has a giant foot print, so most likely not overly heavy in any one spot. I think making sure it is secure from shifting would be the bigger issue. It would be nice to just toss it in there and not worry about it, but that isn't the best option.
JackE is offline   Reply With Quote
Old 07-28-2021, 07:15 PM   #23
Year: 2009
Coachwork: GMC
Chassis: 3500
Engine: 6.6 Duramax
Bed frames are designed to be still all the time (well most of the time) the metallurgy of the bed frame may not work with all the jostling a bus does, brinelling issues and so forth. Just a thought
Hiyu is offline   Reply With Quote
Old 07-28-2021, 07:55 PM   #24
Year: 2009
Coachwork: GMC
Chassis: 3500
Engine: 6.6 Duramax
Two questions: Does it matter which side my black tank discharge valve is on and how does one start a new thread?
I have a mini skoolie and it would be easier to have the dump valve on the passenger side of the bus at this point.
Thank you
Old 07-29-2021, 06:31 AM   #25
Click on the Forum button up top, then click on whichever forum is appropriate for your new thread, then click the New Thread button.
Old 07-29-2021, 07:50 AM   #26
DeMac's Avatar
Chassis: RE-300 42ft
Engine: 466ci
Rated Cap: 90
Standard bed frames are made of spring steel, which is difficult to permanently "brinelling" or bend.
Old 07-29-2021, 08:30 PM   #27
Rwnielsen's Avatar
Chassis: TC2000, 40' MPV
Rated Cap: U/K
Originally Posted by milkmania View Post
Don't forget All-Thread comes in heat-treated and non-heat treated...
In life or death situations, I think I'd want heat treated.
Unistrut and all-thread both come in stainless too but I imagine it's pricey
Rwnielsen is offline   Reply With Quote
Old 10-08-2023, 07:00 PM   #28
Year: 2009
Coachwork: GMC
Chassis: 3500
Engine: 6.6 Duramax
I hung mine similar to yours, but mine was only a thirty gallon tank. I hung one end using carriage bolts, with a plywood board centered and the other end was shimmed off a cross frame. Very solid. I then cradled the tank on three sides with two by fours, and the fourth side I injected foam between the tank and rear cross frame. It's solid as can be. We were t boned a few weeks back and that system didn't budge at all.
Old 10-08-2023, 08:26 PM   #29
Yeah, water is heavy. I would put all thread up through the storage bay and catch the frame. Maybe consider every foot front and back of the tank and bridge it with unistrut
