Old 03-02-2019, 11:13 PM   #1
Coachwork: Amtran RE
Chassis: International 3000
Engine: T444e 7.3L
Help me connect this propane tank
I bought one of those Flame King 100 lb., 29.3 gallon propane tanks from Amazon.Click image for larger version
I installed it under the bus, bought a POL to Type 1 adapter
And...
It doesn't fit my propane tank. Is it a bad adapter, or does this particular propane tank have a different kind of connection than I thought? There is no documentation on the Amazon page, the manufacturer's page, or with the propane tank itself.
Biscuitsjam is offline   Reply With Quote
Old 03-02-2019, 11:18 PM   #2
Year: 90
Chassis: international
Frame mounted tanks do not use the pol adapter. The manufacturer can tell you what fitting to use.
Old 03-02-2019, 11:21 PM   #3
Did you try to turn it counterclockwise. Most propane fittings are a left handed thread.
Shortbuswillow is offline   Reply With Quote
Old 03-02-2019, 11:29 PM   #4
Engine: T444e 7.3L
Except they don't... no documentation on their website, with the tank, or on the tank itself. Any idea what kind of connector I need?
Old 03-02-2019, 11:30 PM   #5
Engine: T444e 7.3L
I tried that - no luck.
Old 03-03-2019, 07:19 AM   #6
Year: 2010
Coachwork: Coach & Equipment MFG
Chassis: ford E350 superduty
Engine: 5.4 liter v8
Rated Cap: 7 passenger
I would take it to your local rv/camper dealer they would know what it needs for a fitting as that is an rv tank
2010 ford e350 superduty v8 7 passenger bus
pbeggs is offline   Reply With Quote
Old 03-03-2019, 08:14 AM   #7
2kool4skool's Avatar
Don, Mary and Spooky the cat.
Old 03-03-2019, 11:56 AM   #8
Jolly Roger bus 223's Avatar
Year: 86
Chassis: Ford B700
Engine: 8.2
Try looking for a connector for an ACME valve,quick closing valve, OPD.
Might even be just start off with a standard BBQ grill hose connector to a valve mounted ridgid which would give you some flex line out of the tank?
Good luck
Jolly Roger bus 223 is online now   Reply With Quote
Old 03-03-2019, 05:49 PM   #9
https://www.googleadservices.com/pag...64236915120661 You need a hose of this type and a regulator. Call etrailer, they are very helpful.
Old 03-31-2019, 06:31 AM   #10
Ninjakitty's Avatar
Engine: 6.6 New Holland Diesel
Rated Cap: 60 kids, 10 window
I'm not a propane expert, but I put my two stage regulator directly to the valve on the tank. If you aren't using lines rated for high pressure, your going to have a bad time when you turn the valve on.
IMO/experience, most of the lpg items will probably be close to the water columns needed to run. Check what all of those are first and build the system accordingly. Make sure your lines are large enough to carry enough volume of propane whatever distance they need to go.
Nick
