08-09-2018, 12:49 AM
Chassis: A3RE
Engine: 3126 Cat
Rated Cap: 33220 GVwR
I need electric heat for my Skoolie
Greetings everyone,
Once again wifey put her foot down and there will be NO propane on this Skoolie. With that said do anyone have any suggestion?
The Rev.
Don't Fret God's Not Through With Me Yet!
08-09-2018, 02:18 AM
Coachwork: None yet
Wood stove
08-09-2018, 05:28 AM
we have a couple of these
1200 watt infrared heater
they work great because they heat surfaces not the air, of course we are plugged in when we use them
08-09-2018, 05:44 AM
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
Your subject and text leave me guessing but some options might include the following. Of course, it varies depending on how much heat you need, what power sources you have available, and so forth...
Diesel fired air heater
Diesel fired coolant heater (then radiant floor heat and/or heat exchangers)
Electric baseboards
Ceramic heaters
Wood heat
Oil filled radiator type heater, electric powered
Roof mounted heat pump
08-09-2018, 12:15 PM
Chassis: Thomas
Engine: CAT 3126
My mini split ac units are also heat pumps and work great for heat down to the 20s or 30s. Very energy efficient compared to most electric heat options.
08-09-2018, 01:49 PM
We use a Planar diesel fueled furnace in our 26 ft. shorty. Model 44D. Uses 12v at a low rate.
Don, Mary and Spooky the cat.
08-10-2018, 09:29 AM
Just for the record...
as I understand it, the majority of RV fires are electrical.
08-10-2018, 11:09 AM
the price of a diesel heater has dropped to a fraction of what i paid for mine. made in China now. i'm going to pick another one up as an add on.
08-10-2018, 12:42 PM
So for someone completely new to the idea of diesel heat, can you share a link to the unit you're considering adding? You said the magic words "price", "drop" and "fraction"!
08-10-2018, 12:46 PM
For those interested in diesel heaters, I googled "diesel furnaces" and got a whack of sites for info. From Webasto to everything else in the market.
New prices seem decent to me and so many to choose from.
Enjoy.
08-10-2018, 03:15 PM
Chassis: Bluebird
Engine: 5.9 Cummins/Allison
Rated Cap: 74
I am putting in 2 mini splits 1 fore 1 aft and I am also putting in carbon film floor heat as an experiment. mini splits are 9000 btu one will be run on a 3500 watt pure sine.
08-10-2018, 04:46 PM
FWIW: used Webasto heaters show up on EBay from time to time.
I found a Scholastic 45k Btu heater for $495+$125 shipping.
08-10-2018, 10:20 PM
my Planar Diesel Air Heater was a Russian made brand. i have their 8DM Model that puts out 21k btus or about 6KW.
this model:
https://www.ebay.com/itm/Autoterm-PL...itleDesc=0%7C0
but if you just search on Planar diesel air heater
here is a bigger one:
https://www.ebay.com/itm/8KW-12V-Air...RC0.A0.H0.TRS5
you can find them on alibaba for about the same price. Apparently the Russians started getting them from China now.
Diesel heater takes a bit getting used to.... outside the bus, it sounds jet engine-ish.
inside is nice and warm
08-11-2018, 05:49 AM
Engine: 345 international V-8
home oil furnace is another option, they make small ones for rv's. An oil furnace uses no. 2 diesel.
08-11-2018, 07:48 AM
Thanks man that got me started!
08-15-2018, 04:15 PM
Year: 2005
Chassis: Frieghtliner - 40ft overall
Engine: 210hp Mercedes Benz Diesel
Rated Cap: 71 person (originally)
propane, unless you don’t plan to travel in winter, you plan to be wedded to shore power and/or a genset.
08-15-2018, 04:17 PM
Diesel heater or divorce. LOL. Seriously, a diesel heater uses fuel you already carry so safety issues should not be a big deal.
08-15-2018, 08:07 PM
Year: 1969
Chassis: Ford B-750
Engine: 390 BB
Rated Cap: 2 humans, 1 cat
We have an EnviHeat in both the front and back of our Skoolie. Quiet, take up minimal space, and EFFECTIVE.
08-16-2018, 11:59 AM
Rated Cap: 71
WanderingLass, could you show me how you utilized your EnviHeat? It seems super inexpensive and maybe too good to be true. Lol. How does it work with your electrics?
08-17-2018, 12:56 AM
Year: 1969
Chassis: Ford B-750
Engine: 390 BB
The front one is mounted beside the steps, on the wall. The rear one is beside the bed. It's actually mounted on a cabinet door! The cord is zip-tied in place so we don't have to worry about it.
We are 95% A/C on Wanda so we're pretty much shoreline dependent with a household breaker panel under a dining room bench. The draw is only 475 watts per heater so we can go solar quite easily. It's not a fast heat so it takes a bit to feel the heat if they're turned off. But WanderingJuggler was able to hit the edge with a kero heater then run just the Envis last winter in South Dakota while working on her (we couldn't leave the skoolie plugged in during the week when we weren't working on her).
