Old 10-23-2017, 11:47 AM   #1
Gunnison Cowboy's Avatar
Engine: Chevy 366
Rated Cap: 71 passenger
Ideas regarding sunken shower pan
We are considering lowering the shower pan by cutting a hole in the floor of the bus and framing with steel (most likely), etc. and getting the shower pan to be sunk about 8"-12" below the inside floor surface.
Anyone out there that has done this and can provide photos, etc. would be greatly appreciated!
thanks!!!
Gunnison Cowboy is offline   Reply With Quote
Old 10-23-2017, 11:51 AM   #2
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
thanks!!!
Good idea ! I'd go even deeper and have a full sunken tub !! A welded pan w/ a flange dropped into the hole would be cool, obligatory spray foam exterior. Make the floor out of Plexi and you could see the fishes go by....
Old 10-23-2017, 12:01 PM   #3
Engine: Chevy 366
thanks Rusty! Any pictures?
Old 10-23-2017, 12:23 PM   #4
Traveling
Rated Cap: '00
Me??? No, this is your pan plan. If you want to save some dough (and I know you do.... Get a used commercial stainless sink and have the fabricator (you) start with that. Hit it w/ sander/wire wheel when done to make look pretty and add swirls, lines, whatever machine finish you want. Straight polish might get slick. Bonuse: It has a drain already, just may require support below if thinner.
Used commercial because is thicker / better stainless.
Old 10-23-2017, 12:28 PM   #5
Engine: Chevy 366
wow, awesome idea, thank you very much, I'll let you know how it goes!
framing, plumbing, shower
