Old 09-04-2017, 05:51 AM   #1
Inspection Lid
Do I really need to install inspection lids on my tanks? Thanks.
willvalenton is offline   Reply With Quote
Old 09-04-2017, 12:47 PM   #2
Njsurf73's Avatar
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
I didn't plan on putting them on mine, but I may now that you have brought it up. May come in handy if it ever clogs...
Old 09-04-2017, 01:39 PM   #3
My theory on maintenance is that if there is something you can't get to, that will be what breaks. If you have any doubt about whether it's needed, just consider how much easier it will be to install it before a problem crops up as compared to later if/when there's a problem.
lucasd is offline   Reply With Quote
Old 09-04-2017, 04:59 PM   #4
BowserJournal's Avatar
Chassis: Ford B600
Rated Cap: 20 person
Same Question
I have thought about this myself and have considered covering mine over. I am considering not now....
"Living Our Own Story"
The Bowser Journal
Watch our adventures by subscribing...
Youtube - bit.ly/TheBowserJournal
BowserJournal is offline   Reply With Quote
Old 09-04-2017, 05:55 PM   #5
roach711's Avatar
Rated Cap: 19
It's nice to be able to have a look inside and to clean out the inside when winterizing. They're easy to install.
The Roach Motel
Old 09-04-2017, 08:47 PM   #6
bus-bro's Avatar
Engine: 3208 na boat anchor
I wouldn't put a hand hole in a tank because that would be a major source of potential leaks, let alone how do you access the access. Pooh tanks with a straight drop toilet can be washed out through the toilet. A grey tank shouldn't get too much in the way of solids.
Water tanks, filled by filtered water, and kept dark, shouldn't need cleaning.
Old 09-05-2017, 08:09 AM   #7
Chassis: Ford B600
BusBro
My floor has two big circular openings right over the tanks. I had wondered what they were for until comming here. Evidently its to inspect or repair/replace the lines above my fuel tank I was just going to cover them but this will still allow me access to the top of the tank like the manufactured created. Its not, at least for me, to gain access to the inside of the tank.
The Bowser Journal
Old 09-12-2017, 07:38 PM   #8
Engine: 8.3 Cummins, 643
Originally Posted by BowserJournal View Post
BusBro
I think they were referring to waste water tanks
Jacob is offline   Reply With Quote
