Old 06-12-2017, 01:29 PM   #1
bigskypc50's Avatar
Coachwork: AMTRAM
Chassis: INT
Rated Cap: Big Girl
opinions on water heater Excel Ventless Tankless
Has anyone installed and used the ventless and tankless water heater seen here
TANKLESS GAS WATER HEATER "Low Water Pressure" Startup Technology
What has your experience been with that unit? Is it worth it? Any problems?
I was looking at ecotemp models but don't want to mess with the venting. 1.6GPM seems to be the only draw back that means low flow everything.
bigskypc50 is offline   Reply With Quote
Old 06-12-2017, 02:30 PM   #2
Njsurf73's Avatar
Chassis: Bluebird
Engine: 5.9 Cummins 24v
Rated Cap: 72 pax
I have never used one of these, but have been looking. Usually vent free means moisture inside the bus from combustion of the propane. Other than that.. I would have a CO detector for my peace of mind.
Old 06-17-2017, 03:55 PM   #3
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
I'm going the European route - a separate 5 and 30 litre boiler setup. Of course, I'm stationary, so I don't have to worry about using LP to heat my water.
Old 06-17-2017, 05:26 PM   #4
Year: 1994
Coachwork: Custom
Chassis: Bluebird
Engine: International straight six
Rated Cap: Unknown
i bought one second hand of craigslist for 100$ it lasted a few months i mounted it on the exterior of the bus for easy venting the problem i had is it stopped working and repairs are very expensive you need to filter the water very good before entering the heater or it will become faulty what i am doing now is i gutted the water heater took the copper core set it over the fire pit and piped it in works great
Cabinbus is offline   Reply With Quote
