Old 04-29-2005, 03:23 PM   #1
Plumbing ideas
OK, so we're planning on putting a toilet in the bus. The main things we're looking for are simplicity and cleanliness - I don't want a damn tray to pull out.
What we're considering:
Using a regular home toilet, but one of the smaller versions.
Using a PVC pipe, maybe 18 inch pipe to be the water source. We plan on mounting it up high and just filling it up with a hose. A few feet of that should provide a lot of water.
COnnecting our water source to the toilet in the same manner that you'd hook up your home toilet
Using some kind of resivior underneath. That is the part we're really not sure of.
So what do you all think? Any better ideas out there? We're definetely open to suggestions!
66 Chevy Skoolie
Used for Tailgating to Kansas State University football games!
The seats are out (except for two facing each other) and replaced with matching couches.
7000 watt generator powering 2 6500 btu A/C's
Rebuilt 350 puts the power down.
66ChevyTailgater is offline   Reply With Quote
Old 04-29-2005, 03:36 PM   #2
Easiest thing is to use a black water tank, it will mount under bus, you can either hook your toilet up to a freshwater tank with a pump of if availible a water hose is fine then when you flush it goes into tank, which can be emptied at any campground and alot of rest areas, sounds complicated but it really is simple and not too expensive.
~B~
1979GMC6000 is offline   Reply With Quote
Old 04-30-2005, 08:48 PM   #3
skoolie_grease's Avatar
~B~
And there's supposed to be a vent of some sort on the route to the black water tank? Is that correct? or is that on another part of the water sewage system?
sKOOLie: 1992 International 7.3L Diesel Short Bus
...:: http://www.skoolie.info ..::.. http://www.goodgrease.com ::...
skoolie_grease is offline   Reply With Quote
Old 04-30-2005, 09:07 PM   #4
Re: Plumbing ideas
Here's a pretty detailed explanation:
http://www.skoolie.net/forum/viewtopic.php?p=4028#4028
Plumbing question flamedeep Conversion Tutorials and How-to's 9 08-29-2012 01:01 PM
Plumbing... on the way~! How hard was it to do??? usmcbay Conversion General Discussions 8 05-08-2012 11:08 AM
Plumbing questions Abbott Plumbing, Water and Waste 21 06-10-2008 08:46 PM
Heater Plumbing wmah Conversion General Discussions 2 08-14-2007 10:21 AM
plumbing question deadhead Plumbing, Water and Waste 13 04-18-2007 04:09 PM
