Old 08-26-2014, 06:28 PM   #11
Re: PLUMBING QUESTION, VENT RELATED
Originally Posted by lornaschinske
David & I have been talking about what you are trying to do. We have found a few issues that may give you problems later with tanks. My question is, are you planning on adding holding tanks later?
honestly....no...reality is if we "had" to live of grid because of an emergency whatever......a hole in the ground would work just fine, hell out houses have been used before
when we "Glamp" we want 50 amp or atleast 30...so we can have guests and party w/o blowing a fuse....you have seen what happens then?...right? who ever goes to "just flip the breaker back"
looses there head or their heart falls to the ground with thier stomach
so I really dont see holding tanks in the future
And with 15 ft of 3" pipe I would need a real...real...emergency to have to use it on the road....at that point...fill it up
Old 08-26-2014, 06:50 PM   #12
Engine: 5.9 Cummins, Allison 545
15' of 3" pipe will give you a hair over 5g of storage. thats just right for a single flush from a standard toilet
Turfmobile Build Thread
Old 08-26-2014, 07:01 PM   #13
yup with one in the chamber ..... .......
kind of my hi-way goal
we should have pictures of something by sunday....3 days until me and my friend head out....still got porto pot under shelf
ugh...gotta go and check...hope it's clean from last trip
Old 08-26-2014, 07:04 PM   #14
lornaschinske's Avatar
Rated Cap: 89
Two flushes (or more) with a current low flow standard residential toilet. Some I just looked at were dual flush using 1 gal for "liquids" and 1.25 for "solids". None on the shelf used over 1.25 per flush. Our cheapo $68 toilet is a 1.25 gal per flush. My math is probably rusty but I come up with 4 flushes to equal 5 gallons so 3 flushes for safety (although my tank calculator shows 6 gallons for a "tank" that is 3 inches in diameter and 180 inches in length).
Fulltime since 2006
Old 08-26-2014, 09:30 PM   #15
All right, Enough potti talk for now. Where you and your friend heading out to? Will you remember to take your camera? Love, Mom
Old 08-27-2014, 05:22 AM   #16
outer banks in NC...and always have the picture machine with me
Old 08-27-2014, 05:28 AM   #17
cheater valves...ahhh...so why vent toilet thru roof?
couldn't I just install one of these at toilet under floor at the top (under skirt)?
so toilet flange, 12 inch drop with vent, then curve to 3 inch long pipe, this should put the vent about 2 ft above mainline
Old 08-27-2014, 07:45 AM   #18
i've never used a AAV, but i think they need to be above the water line of the toilet..... otherwise it would just be another drain opening.
venting through the roof also lets gas escape from your holding tank (3" pipe) to keep the smell out of your cab.
Old 08-27-2014, 08:54 AM   #19
not sure, if they work under a kitchen or bathroom sink inside your house, then it should be fine used under the floor and shouldn't leak gas out....right
water drops a foot past the vent intersection and flows down through 3" pipe, and the vent goes up a foot plus...should keep liquid out
gosh my brain...I feel like I have chemo brain today
Old 08-27-2014, 09:03 AM   #20
Rated Cap: 89
A Cheader/Cheater/Schrader valve is a Air ADMITTANCE valve. A one way valve that allows air to only travel in ONE direction which is into the pipe, not out. Any holding tank, fresh, grey or black, must allow air to flow both ways as the tank must be able to expell the air the liquid displaces as well as allow the intake of air for when the liquid leaves the tank.
You need to vent not only your holding tanks but your drain lines. Air must be able to enter the main drain between the P-trap and the main drain.
Is the sewer side at the toilet or at the galley sink?
Fulltime since 2006
plumbing vent and hepvo turf Plumbing, Water and Waste 25 01-09-2014 04:15 PM
Plumbing question flamedeep Conversion Tutorials and How-to's 9 08-29-2012 01:01 PM
Plumbing question BUSFREAK08 Conversion General Discussions 3 04-25-2011 09:20 PM
Powered roof vent question BUSBOZO Conversion General Discussions 0 07-13-2010 08:31 PM
plumbing question deadhead Plumbing, Water and Waste 13 04-18-2007 04:09 PM
