Old 04-20-2018, 11:31 AM   #1
Plumbing stuff. What else do I need?
Okay so long story short, I am salvaging what I can out of a totalled Class C RV my BIL owns (Serious water damage to the coach work, non repairable unless we want to fully rebuild the coach!)
So the plumbing related items we have salvaged are...
  1. 40 Gallon fresh water tank.
  2. ? capacity gray water tank.
  3. ? capacity black water tank.
  4. Black and Gray water dump valves.
  5. Tank sensor / control panel.
  6. Stainless steel 2 bowl kitchen sink.
  7. Oval stainless steel lavatory sink.
  8. Stainless steel low rise kitchen sink faucet that I hate.
  9. Chromed plastic lavatory sink faucet.
  10. Chromed plastic RV Tub / Shower faucet and diverter assembly.
  11. RV Tub / shower enclosure / assembly.
  12. Yellowed white Oxygenics shower head.
  13. City water inlet piece with locking door.
  14. Misc braided PVC hose, and clamps.
The water pump and hot water heater are known to be bad. and need to be replaced.
I have a nice high rise Glacier Bay (Home Depot Delta clone) brushed nickel / stainless steel faucet with pull out sprayer I am intending on using instead of the low rise RV unit.
I have a nice, refurbished by me, Delta single handle chrome faucet I am planning on using for the bathroom instead of the chromed plastic piece.
I know I am going to need the following items, and am looking for the best deals on them.
  1. Ecotemp or similar on demand hot water heater. But which one?
  2. 12v water pump. Again, which one?
  3. Chrome Oxygenics shower head.
  4. Porcelain, elongated bowl RV Toilet. (Best deal on a Dometic 320?)
I am pretty sure I am going to need valves, check valves, pex piping, but how much, and any clue what I should be looking to pay?
The tub assembly is interesting. It's basically 4 pieces, the tub, and the 3 walls (1 piece each). The tub is built sort of like a residential unit, but a LOT smaller, and is plastic resin over what appears to be stainless steel, with a steel beam / cleat on each side to bolt to... The shower walls appear to be simply plastic sheets. The original attachment looks like liquid nails, and not a lot of it. There was a little bit of caulk sealing things up. So....
Looks like I am going to want.
  1. Stainless steel wood screws to attach tub to framing.
  2. Liquid Nails for projects to attach shower surround.
  3. Tub and tile caulk to seal the seams, and penetrations.
  4. Pipe tape to seal the plumbing joints.
  5. One of those shower curtain rods that bows in / out to make more room in the shower. I'm a big dude, I need the space...
  6. Shower curtain / liner.
What else am I missing / not thinking about?
dbhost is offline   Reply With Quote
Old 04-20-2018, 12:14 PM   #2
Chassis: Saf-T-Liner MVP ER
You will want cement board behind the shower walls. Plywood isn't good enough.
Steve Bracken
Build Thread
Old 04-20-2018, 12:44 PM   #3
Chassis: 3000RE
Engine: T444E w/ MT643
Rated Cap: 84 pass, 40'
Or redguard. You can paint that onthe plywood. Or a waterproof membrane at least 12" up the side walls.
2martins is offline   Reply With Quote
Old 04-20-2018, 03:23 PM   #4
Ninjakitty's Avatar
Engine: 6.6 New Holland Dies
Rated Cap: 60 kids, 10 window
I'm going to use hardiboard with redgard.
Nick
Old 04-20-2018, 05:44 PM   #5
So you guys know what you are doing, but for anyone else I'll still recommend cement-board.
The key property is that it doesn't flex like wood, and in a mobile situation you do want the walls behind the shower to move as little as possible.
In a home, the house doesn't move
Steve Bracken
Build Thread
Old 04-20-2018, 08:10 PM   #6
Hardiboard is nice because you can get it in 1/4" thick which saves on weight and dimensions. Every square inch on a build is important.
Old 04-21-2018, 12:06 AM   #7
Ninjakitty's Avatar
I've used both cement board and hardiboard in non-mobile applications. I'd recommend Hardi board for the ease of install. I'd also recommend Redgard or Aqualock type paint on products for the waterproofing membrane which is the most important part in a shower or bath area. No matter the substrate behind the membrane, keeping it dry is the important part.
Nick
Old 04-22-2018, 09:30 PM   #8
Coachwork: Girardin
Chassis: E-350
If you're more adventurous, you can make your own ultrasonic tank level sensor:
Measuring Water Level With Ultrasonic Sensor: 7 Steps
TheArgobus is offline   Reply With Quote
Old 04-24-2018, 11:11 AM   #9
Wouldn't some flexibility be desireable in an installation that is going to be bumping, shaking, and vibrating its way down less than optimally maintained roads?
Old 04-24-2018, 12:04 PM   #10
No, it needs to be stiff and we use high-flex elastomeric sealant.
The Hardiboard is cement board, it's just a brand name.
Steve Bracken
Build Thread
