Old 06-13-2009, 08:46 AM   #1
Coachwork: 2003 Thomas E-350 shorty
Chassis: E350
Engine: 7.3 Powerstroke
Rated Cap: 24
Re: Pros/Cons of holding tanks inside the bus
Only addressing the smell issue: The only ways for smell to escape the tank(s) are the toilet, sink and shower if you have one. Also the vent and dump valves. These are all present regardless of tank location. Keeping the P/J traps full will take care of sink etc. Of all of these, the only items that will differ greatly for an inside located tank are dump valve(s). For the dump, I would build a small recessed compartment around the valves, with an exterior door. Seal it real good so the valve system is isolated and entirely outside. Other possibilities for an inside tank are poor sealing at the inlets and outlets, and then cracks in the tank. Another non-smell issue to deal with is making a sturdy platform for the toilet. It'll need to be over the tank. Depending on tank dimensions and location, could get interesting, especially if you have a low roof. Low profile RV toilet will come in handy here.
If it isn't grown, it has to be mined
elkoskoolie is offline   Reply With Quote
6.0L / 6.3 / 7.3 - anyone have pros or cons to share? wirelessguyNY Ford Drivetrain 3 12-20-2014 02:14 AM
FE vs. RE - pros and cons... The Painted Lady Everything Else | General Skoolie Discussions 6 02-11-2014 09:40 PM
PROS/CONS of a Roof rack? GreyEagle Everything Else | General Skoolie Discussions 7 03-04-2013 08:03 PM
Window choice pros and cons bapos Conversion General Discussions 19 07-24-2012 11:53 AM
Pros / Cons Of Different Bus Platforms? bus-bro Mechanical and Drivetrains 5 12-19-2011 09:03 PM
