Old 06-15-2017, 06:30 PM   #1
Setting up bus for external water connections only?
Has anyone ever set up their vehicle with no holding tanks, just external connections? We're trying to do the bare minimum to convert the bus to an RV status for the Alaska DMV since getting CDLs is looking increasingly difficult. (Currently there is a 2-month waiting list for road tests. And please don;t bring up the Vermont loophole or try to tell me that we don't need CDLs for personal use.)
I need to meet at least one of these two requirements, and #4 seems the lesser of two evils. I can sort of see how we could do a city water connection and run it straight to the sink, but what about gray water?
2) ____ Self-contained toilet or toilet connected to a plumbing system with connection for external water disposal.
4) ____ Portable water supply, including plumbing and a sink with faucet either self-contained or with connections for an external source.
mh_ccl is offline   Reply With Quote
Old 06-15-2017, 06:50 PM   #2
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
You can get a composting toilet to satisfy the self-contained toilet.Nature's Head Composting Toilets -- The Official Site
Plumbing directly from city water is as simple as hooking up a potable water hose to a source. Disposing of gray water would require another hose from a common drain to a disposal drain, probably of larger diameter.
Apparently in Alaska, the type of license depends on your GVWR. If your GVWR is LESS THAN 26000, you can get by on a Class D (normal) license. So, to answer that question, how heavy is your skoolie?
Old 06-15-2017, 08:05 PM   #3
GVWR is 30K. Plus it was designed to carry more than 16, thus it would require the CDL. (Sorry if I sound cranky about this. Nearly everyone I talk to locally tries to tell me I don't need a CDL. Except the DMV. They say I most definitely do.)
The cost of buying a toilet is more than we want to spend right now. We're putting this stuff in to meet the requirements, but will remove it before we hit the road. In the long run, we'll have a toilet and fresh/gray/black tanks and everything, but for now we need to use the vehicle to move down to the Lower 48.
So it sounds like I could set up the sink drain to connect directly into a gray water hose, and then would put that into a disposal drain at a camp site. And set up a city inlet hookup that would connect right to the sink.
Most likely we'll jump through all these hoops and they won;t even go out to the parking lot to look.
Old 06-15-2017, 08:24 PM   #4
Robin97396's Avatar
Some DMVs will accept mockups inside the bus. Bed, camp stove, water jug, chemical or composting toilet, something that resembles an electrical system.
You can make your own composting toilet.
Robin
Nobody's Business
Old 06-15-2017, 08:35 PM   #5
My original composting toilet cost me less than $40 to build. It took me a couple of hours to build. I did add a urine diverter later and that added about $60.
If that is too expensive you may find the entire conversion process a financial challenge.
Good luck!!
Old 06-15-2017, 08:38 PM   #6
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
2 cents.
Being rural makes it harder, but what I do is shop for a DMV location or even person that is amenable and knowledgable to get transactions completed.
You can go and start the proceess, and if given grief, bail and say you forgot your checkbook...come back when they go to lunch.
I do many oddball DMV transactions (SF97) - ours limits me to 10 titles/day to give you an idea of my level of familiarity.
Polite, contrite, yes ma'am your way. My state requires the special Secretary of State Police to inspect your potential motorhome- at your house- prior to switching to RV, but I smiled and was pleasant last time, and my ambulance is an RV now, despite none of the requirements.
Old 06-15-2017, 09:10 PM   #7
Robin97396's Avatar
I thought finessing DMV personnel was something I invented? Guess not.
Steve; Have you looked into the batteries from an electric walk behind pallet lift? Lots of them for sale currently.
Robin
Nobody's Business
Old 06-16-2017, 01:56 PM   #8
I should clarify that we do not want a composting toilet for our bus for the long-run, therefore it wouldn't make sense to pay $1K plus shipping to get one just for now. I've spoken with our DMV, and they will not accept anything like a handmade composting toilet or one of those camp toilets that sits on top of a small tank. She was pretty clear that it would need to connect to a black water tank or external sewage connection. Thus, we're pursuing the water setup for a sink instead.
We've discussed our long-term bus layout ideas and where we believe we'll locate the water tanks in the future, and have agreed on where we can put in our city water inlet valve. We will plan on connecting the drain to a hose for direct gray water drainage.
Old 06-16-2017, 02:16 PM   #9
Robin97396's Avatar
You seem to know very well what you need to make the DMV happy. That obviously conflicts with what you would like to do. If you want to put your bus on a foundation you can certainly hook it up to standard sewer hookups and city water, but that's not an RV.
As I understand it there are pretty big fines for dumping even grey water, not to mention the black tank. If you want to be mobile with an actual bathroom you will have to have tanks.
Then again for a long time I've had this idea of making a outhouse slide-out that doesn't need plumbing.
Robin
Nobody's Business
Old 06-16-2017, 03:18 PM   #10
Better warn the Wife not to use it while you are driving........ Oncoming traffic can play hell with the slide out.....
