Old 07-29-2019, 05:13 PM   #11
Originally Posted by alpine44 View Post
How were the walls attached to each other and to the pan? Would it be possible to reduce the depth of the stall?
The 3 walls slide into corner brackets and a channel at the base. The base is a closed 4 sided pan, don't know how you would address the front lip if you shortened the pan. The pan is only 32"
Old 07-29-2019, 05:44 PM   #12
Coachwork: American Cargo 14'L x 7'8"W x 7'H Box
Chassis: Ford E350 Cutaway
Rated Cap: 11500 lbs
Thanks for the info. The best price for this stall I could find locally is $220 but still better than buying the pan, wall sheets, and corner extrusions separately.
alpine44 is offline   Reply With Quote
Old 07-29-2019, 05:55 PM   #13
There's one on Ebay in Ct. for $155, unfortunately it is pick up only
Old 07-30-2019, 01:07 PM   #14
Coachwork: International Harvester
Chassis: S1753
Engine: V8 6.9L
How Do I Achieve This? Not Exactly This, But With The Deep Pan.
File Type: jpeg FE11715A-5740-42C4-A481-5C7B2BFC8E09.jpeg (374.4 KB, 30 views)
NfiniteMile is offline   Reply With Quote
Old 07-30-2019, 01:25 PM   #15
That is very cool looking!
Unfortunately, I don't think I could get my old decrepit self in and out of it
Old 07-30-2019, 01:54 PM   #16
I've seen where someone sunk one into the floor about a foot.
Old 07-30-2019, 02:08 PM   #17
How much room do you have and what’s your plan? Bathtubs use a lot of water. Those troughs are available at most livestock supply places.
Some tin ceiling tiles, a little wood. Bob’s your uncle!
Old 07-30-2019, 03:43 PM   #18
HazMatt's Avatar
Chassis: IH 3800, 8 window
Good call!
Old 08-14-2019, 08:11 AM   #19
Evey_c's Avatar
Coachwork: Chevy Express Hi Cube Bus
Engine: 6.0l
So you still framed it out? Does it need to be framed out? Iím not very handy in construction and Iím trying to do a lot of this by myself.
Evey_c is offline   Reply With Quote
Old 08-14-2019, 11:13 AM   #20
There is a 1/4" lip on top of the pan. You need to frame a wall and skin it with 1/4" plywood to give the flimsy sides strength.
