Old 02-27-2008, 10:40 AM   #1
Coachwork: 1976 Bluebird
Chassis: 1994 Peterbilt
Engine: 8.3 Cummins I/C Turbo
Tips for installing Dometic 510
I am getting ready to install a new toilet in a new location (Dometic 510 china bowl), do you have any tips that I should know. I have never done it. I have a black water tank to install with plenty of room for my lines. What is the ideal size for pipes, do I need a macerator in the line, and which side of the bus does the dump valve need to come out on ? What is the best type of dump valve and hose to use? These may be stupid questions, but I just want to be sure I don't mess something up. I have read some of the threads on this forum and they have helped also. Thanks, Marty
PeterBird is offline   Reply With Quote
Old 02-28-2008, 10:55 PM   #2
Re: Tips for installing Dometic 510 (please)
Any help would be appreciated. I have read all I can find, just wanted some advice from someone who has done it. Thanks
Old 02-28-2008, 11:17 PM   #3
Elliot Naess's Avatar
Engine: 5,9 Cummins
Have not installed mine yet, but the drain definitely goes on the left side of the bus.
I have a book that explains all this plumbing and wiring and so forth very well. It is "How To Build Low Cost Motorhomes" by Louis C. McClure, 2004 edition edited by Ben Rosander. You can buy it on the internet if you do a bit of searching on "bus conversions" and that sort of things.
Elliot
Old 02-28-2008, 11:34 PM   #4
oldog12's Avatar
Check out poop sheet by phred:
http://www.phrannie.org/phredex.html
Might not answer your question specifically, but "Macerator and other sewer stuff" has a lot of info for you...
oldog12 is offline   Reply With Quote
Dometic Propane Refrigerator Kelecri Heating, Cooling and Appliances 11 01-09-2017 07:04 PM
Oh no. Dometic RM-2410 fridge flatlines... crazycal Heating, Cooling and Appliances 28 02-02-2016 02:00 PM
Looking at my first mini-bus...any tips? timmygyu Conversion General Discussions 4 11-26-2010 04:16 PM
Tips on what's for me?? SoulFire Conversion General Discussions 0 08-18-2008 05:09 PM
Dometic refrigerator info needed...... eggman Everything Else | General Skoolie Discussions 5 10-27-2006 11:17 AM
