Old 02-01-2018, 07:44 PM   #1
Chassis: Blue Bird
Engine: 8.3 cummins
Water plumbing
I have searched through the plumbing forum and trying to design our plumbing system... What I am curious of is how others have laid theirs out? I wanna grab some tanks for fresh water grey and black water behind rear axle... All water lines for shower sinks etc on driver's side.. can I run my plumbing as in a manufactured home?? Or any direction to some detailed plans of my predecessors as I'm.not trying to reinvent the wheel just fit it to our rig efficiently... Thanks to all!!!!
bman91 is offline   Reply With Quote
Old 02-02-2018, 07:08 AM   #2
JDOnTheGo's Avatar
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
This post may help:
Plumbing - Moving the Liquids - JdFinley.com
Unless you have some local rules/regulation with which you must comply, you can do pretty much anything you want. House/RV plumbing is typical - PEX tubing, PVC for drains, classic p-traps, etc. Finding a place, the right "fit" tank, and mounting them is usually the toughest job. You do have to consider the drains and keeping them running downhill.
JD - Full timer out west
Missy - 1998 MCI 102-EL3 - 1.7kW Solar - 10kWh Lithium
My Adventures & Build
JDOnTheGo is offline   Reply With Quote
Old 02-10-2018, 03:59 PM   #3
Originally Posted by JDOnTheGo View Post
This post may help:
Since plumbing is something I haven't done too much in-depth Googling of just yet, in that link you posted the writer has a pressure accumulator in his system diagram. Is that something that is REQUIRED for reliability, or is that just a precautionary item?
Yuuyia_Takahashi is offline   Reply With Quote
Old 02-10-2018, 04:07 PM   #4
I would prefer to not have all that movable liquid weight hanging off the ass of my bus. My plan is to have most of the plumbing centralized in the bus with the tanks as near the drains as possible.
There's basically only 2 rules in residential plumbing, sh*t doesn't run uphill, and hot is always on the left. If you have a composite toilet, only one rule applies.
Was just watching the ARCA race and a Menards commercial came on promoting SiouxChief plumbing products, much of which could be used in our builds.
Support | Brackets | Stub Out Brackets | Bend Supports
Old 02-10-2018, 04:17 PM   #5
Not to highjack the thread, but I'm assuming you mean having your tanks mounted between the axles for weight distribution purposes as well as to making plumbing lengths as short as practically applicable?
Old 02-10-2018, 04:27 PM   #6
Exactly
No hijack, topic related.
Old 02-10-2018, 04:29 PM   #7
Chassis: Saf-T-Liner MVP ER
The pressure accumulator is an affordable device that prevents the system "pulsing", and allows steady water-flow at the faucets.
Steve Bracken
Build Thread
Old 02-10-2018, 04:39 PM   #8
Ahhhh, gotcha. I'd assume it's a NVH consideration as well as a longevity thing? because I'd suspect that the pulsing isn't good for the pumps and equipment?
Old 02-10-2018, 04:41 PM   #9
I would think it helps the pump quite a lot. Also helps provide a steady flow of water through an instant heater.
Steve Bracken
Build Thread
Old 02-10-2018, 04:48 PM   #10
Got it! That was what I was thinking was pump longevity so that it doesn't accidentally cavitate, which would also harm a point-of-use heater.
Thanks.
Old 02-10-2018, 08:28 PM   #11
Chassis: Blue Bird
Engine: 8.3 cummins
I unfortunately have no room in the center of my rig for tanks gens on either side taking these spaces... In going right behind axle and smaller tanks about only place I have available
Old 02-10-2018, 08:55 PM   #12
What size is you bus?
Old 02-10-2018, 11:46 PM   #13
roach711's Avatar
Figure out how your drains will flow to the tanks first. After that running PEX to the fixtures is easy. Wheel wells and frame rails are the most stubborn obstacles. Drinking water tanks can go inside the bus under a bed or a bench.
Before you mount your black/gray tanks between the frame rails make sure you can run drain lines through the rails without cutting holes into them which will weaken the rails.
Most mount tanks on the driver's side since dump stations are on that side.
The accumulator lets the pump run less often. It's fairly easy to build your own out of PVC pipe so you can build one to fit the space you have.
The Roach Motel
Old 02-11-2018, 08:03 AM   #14
JDOnTheGo's Avatar
Coachwork: MCI
Chassis: 102 EL3
Engine: DD 60
... has a pressure accumulator in his system diagram. Is that something that is REQUIRED for reliability, or is that just a precautionary item?
I installed it purely because I despise noise. Listening to the water pump every time I crack a faucet open is annoying to me. So, in my case, it is purely a "comfort" item.
Old 02-11-2018, 11:01 AM   #15
Chassis: Blue Bird
Engine: 8.3 cummins
Is everyone set up with fresh water tank inside the bus?? And is this standard for a reason?? Thanks ahead of time
Old 02-11-2018, 11:12 AM   #16
I'm guessing the larger holding tanks are too large to mount under the body. Keeping them inside helps prevent the water from freezing. Shorter run lines, less holes through the floor.
Old 02-11-2018, 12:32 PM   #17
I think its for a number of reasons...
Space savings under the bus. If you have a smaller bus or have one with belly storage boxes you may not be able to fit both or all three tanks under the body.
To keep the tank/lines from freezing. (although they do sell tank blankets that are 12v for this purpose also)
Plumbing length, if its in the buss near the water usage points there is less distance for it to travel, making the pump workload less.
Old 02-11-2018, 08:52 PM   #18
IWC Bus's Avatar
Chassis: A3RE
Engine: 3126 Cat
Rated Cap: 33220 GVwR
Water plumbing
So just to jump in here for a minute. What is the pump of choice for most skoolies? I have reviewed so many and I think I am ready to purchase a Shurflo Aqua King ll. I was also thinking about using a Shurflo Pro Blaster ll and run then together (to make a FRESH WATER DUAL PUMP SYSTEM).
I can’t the Accumulator Tank which I have already. I am using a 55-gallon tank and a 45-gallon tank for fresh water, A PEX Manifold. Here is the other big question, can someone recommend a good hot water heater.
The Rev.
Don't Fret God's Not Through With Me Yet!
IWC Bus is offline   Reply With Quote
Old 02-11-2018, 08:56 PM   #19
Originally Posted by IWC Bus View Post
Here is the other big question, can someone recommend a good hot water heateer.
Atwood seems to be a highly regarded brand from my reading so far if that’s any help. I’m sure others will chime in.
Old 02-11-2018, 09:01 PM   #20
Robin97396's Avatar
You can get a residential propane water heater that could run on relatively low amperage from a converted 110 outlet. I have no idea what size you're talking about, or even if there are better alternatives. That's just what I've got on hand is a couple 40 gallon propane water heaters that need 110. I'm not trying to sell anything. Just saying that might work, or variations of it.
Robin
Nobody's Business
