04-23-2019, 10:55 AM
Coachwork: Corbeil
Engine: Ford PowerStroke Diesel 6.0
Rated Cap: GVWR 11,500
Originally Posted by CMORGANSKOOL
Do you have experience with that particular pump? Based on the reviews, I would have been concerned about their reliability.
04-23-2019, 11:11 AM
Edit: wrong water pump!
04-23-2019, 11:20 AM
Chassis: International 1753
Engine: 6.9 International
I would be too. 3 reviews and 2 had case leaks within a few days.
That G9020-47031 is a toyota part number, so for anybody wanting to buy a pump like this, but with better reviews you can use that number.
Good find though, it's a brushless dc motor with the magnet on the impeller. So that means no shaft seals to leak. It isn't self priming though so you'll have to have the water level above the pump.
04-23-2019, 11:32 AM
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
or a foot valve similar in function to the ones used in domestic water systems with wells as the water source - once primed, it would work fine
04-23-2019, 11:46 AM
04-23-2019, 11:50 AM
Coachwork: IC
Chassis: FE Bus
Engine: DT-466 7.6L Turbo Diesel
For cold water use I don’t see this part failing unless it’s defective from the manufacturer. The temperatures and pressures they’re designed to operate in are well above those encountered as a skoolie pump. These typically run 100,000 miles as a coolant pump on Toyota Prius which I have some extensive experience with. Definitely buy the better rated one if it makes you feel better. I’ll post updates on my build if there are any issues. Which I’m sure there will be.
04-23-2019, 11:53 AM
Engine: 6.0L Gasser
At that point, you can spend an extra $15 and get a self-priming ShurFlo pump and be done with it. It may use some more power, but unless you're using a lot of water, this is fine in most cases.
04-23-2019, 12:21 PM
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
another case of where a condemned camper or trailer would have some useful parts, including a pump and holding tanks
04-23-2019, 12:24 PM
Chassis: B3800 Short bus
Neat find! I have an application for just such a 12v pump. I don't want the noise of a diaphragm style RV pump and it's for a closed loop so I don't need it to be self priming.
Another nice feature is that it can be fully submersed.
I think even that cheapo one with bad reviews would work fine for my use. The complaints are about it leaking at the seam which some caulking or JB weld could cure right quick.
Alternatively I may poke around some junk yards for a Prius!
04-23-2019, 03:21 PM
Coachwork: IC
Chassis: FE Bus
My point exactly. This would be great for a tub or hot water application too.
04-23-2019, 06:40 PM
Rated Cap: 37,400 lbs GVWR
The good ol' SHURflo 2088 is still the simplest and most reliable pump out there, and if it's mounted on a resilient pad it won't make as much noise. I have two of them under the floor next to one of the tanks, and when it's running I can't hear it inside the bus at all.
