Old 10-31-2010, 03:19 PM   #1
water pump
looking at getting stuff for the water system, have holding tanks etc, wondering what size of on demand pump to use? Ill have a shower, toilet, bath and kitchen sinks. fresh water will be under bus. anysuggestions would be helpfull.(looking at a sureflow pumps) there for sale every where.
tks
Old 11-01-2010, 10:26 AM   #2
lornaschinske's Avatar
Rated Cap: 89
Re: water pump
I'm partial to the Shurflo 2088 pump. Holds up well and pump head is replaceable at a decent price. I've had several. Our last one to poop out on us was from the late 70's and they no longer made the replacement pump head. Our other pump is still going strong (2.8 gpm from the early 80's). The new expensive Shurflo pumps aren't a good. Lots of RVers have had problems (The sensor ones). The Whisper King is good but the 2088 is till the workhorse of the lot... no frills just hard working and dependable. Some folks like Flojet but I have no personal experience with them. We are currently;y running the 2.8 gpm in the current Class C. It is definitely sufficient to use with a low flow shower head. It's also a little cheaper.
This place has good prices and reasonable shipping. They often beat out everyone else. Make sure you get a check valve for the pump. Some places offer it together, others sell separately.
http://www.adventurerv.net/shurflo-mult ... -1711.html
http://www.adventurerv.net/shurflo-wate ... p-106.html
Fulltime since 2006
Old 11-02-2010, 07:56 PM   #3
Rated Cap: 89
Re: water pump
I have heard only bad things about the Shurflo Extreme 5.7 Smart Sensor. I think it would be better to run two pumps than to invest in the Extreme. Perhaps they have been fixed but I have heard that they leak or the motor poops out.
Me? I would run two pumps and I probably will (need to add a washing machine and a dishwasher). But that's me.
Fulltime since 2006
Old 11-03-2010, 06:07 AM   #4
Re: water pump
When figuring GPM, also figure how many people will be in the bus. A low GPM pump might be great for solo travels, but not so great if someone might turn on the kitchen faucet while you are trying to shower. In our old house, a call of "Here comes the hot!" before a toilet flush would warn bathers in advance of a loss of cold water pressure. I'm just sayin' . . . .
Also, I can't picture running a washing machine or dishwasher off of one's tanks, but saving the loads for when you are hooked to campground/city water pressure and drainage, where the pump size wouldn't matter, anyway. But as always, YMMV.
Old 11-03-2010, 07:16 PM   #5
Re: water pump
lots of great info about water pumps, that sureflow 2088 2.8 gpm sound s like the way to go, prices are good and and they seemm like a good pump, should work ok in my set up, not planning on anything more for use water, like anything else you just dont run all your water at one time
tks
Old 11-11-2010, 03:41 PM   #6
Rated Cap: 89
Re: water pump
Originally Posted by PURA VIDA
...Geez, the way my friend made it sound...I was gonna need the biggest pump out there...
Perhaps your friend thought that you wanted/needed to run a washing machine. Although a washing machine will operate just fine, albeit fills slower, with low water pressure. I know this from experience since we have had water supplies from spring fed cisterns (not much of a head so low water pressure at one place and one was just a low powered pump). Only an automatic dishwashing machine requires 40 lbs of water pressure... perhaps your friend thought you were going to install a DW?
Fulltime since 2006
91 International 7.3 water pump RyanS Mechanical and Drivetrains 1 12-26-2010 03:04 PM
Fresh water pump question BUSBOZO Conversion General Discussions 1 03-22-2010 12:37 PM
12V Water pump for fresh water? ezbme Plumbing, Water and Waste 1 05-29-2009 06:26 PM
Water Pump Help FelixM Conversion Tutorials and How-to's 4 04-10-2009 09:32 AM
12-volt fresh water pump Abbott Plumbing, Water and Waste 4 06-19-2008 08:49 AM
