Old 05-15-2016, 05:25 PM   #1
Where is your freshwater tank located?
I am getting to the point of plumbing and have thought of several different places inside the bus weay put our freshwater tank. Pros and cons to each way. Where is your freshwater tank and why?
Quick pic since we just got done framing
EricW is offline   Reply With Quote
Old 05-15-2016, 05:47 PM   #2
Robin97396's Avatar
My tanks are inside, right under the wall mounted TV. They're inside because otherwise in the winter they would freeze and be unusable, and during the summer they would be hot and prone to algae growth. Indoors they enjoy a moderate temperature in any climate.
I actually use two 55 gallon plastic drums for my fresh water. They're the perfect height for a counter top and they can be easily replaced if they get nasty at any point in the future. RV tanks are about 15 times as expensive as plastic food grade drums and I'll let you guess which one is tougher. I've dropped a full barrel of water and it didn't break. Could an RV tank do that?
Old 05-15-2016, 06:08 PM   #3
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
Mine will be in the basement, along with the grey. I will also be using a blanket heater and lots of insulatioin as well as a heated Potable hose to ensure waterflow during the winter.
Old 05-15-2016, 06:20 PM   #4
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
My fresh and grey water will be in the basement as well. Since we don't plan on fulltiming, they'll be drained in the winter. And if we snowbird, they'll be refilled in warmer climes. I'm also planning on ABS tanks similar to Tango's for fresh; I may use a food grade barrel for grey
Captain Obvious on deviantArt
Old 05-15-2016, 06:33 PM   #5
So are the 2 55 gal drums supporting a countertop or just snuggled under one. How are they secured? And is having the weight on one side a bad idea in terms of weight balance?
Old 05-15-2016, 06:59 PM   #6
Year: 1987
Engine: 6.9L Diesel
Building off the prior post, Robin how do I see your rig? I see you posting everywhere but haven't found your build. But maybe I get distracted every time I look for it.
Old 05-15-2016, 10:26 PM   #7
Robin97396's Avatar
That's because I never started a thread on mine.
I have a problem with that. In Oregon you can not self convert a bus and achieve insurance at any level, other than being able to provide a receipt from a professional coach conversion company. It's a no go that direction. Apparently they are sick of hippies here from years ago.
This is as van technically, because it had no seats when I bought it as a special needs bus. Now titled as a van and insured as a van. Like a Chevy van except much, much bigger. I can use my "maxi-van" like I might use a regular van, but it still requires the commercial policy even though I'm under 25k. I'm technically not allowed to convert this bus to an RV, so should I really incriminate myself on the internet? You ever notice the government busting people based on their facebook posts? No buddy, this is a van. All the accoutrements in this "van" are modular and can be rolled right out of here, and it's a empty van again. Because it's got to be a van legally, and then I do tend to change buses every few years. I got tired of fixing them up. The problem with insurance requires this not be converted. Technically I think I'm still legal, kind of.
Old 05-15-2016, 11:31 PM   #8
So post "anonymous" stuff man.
I REALLY doubt your insurance people or anyone from the state cares what you post on an internet forum in the slightest.
I don't see how its actually "incriminating" to post some pics.
Roll Your Own Build Thread
Old 05-16-2016, 12:03 AM   #9
Engine: Cat 3126e
Rated Cap: 28
x2 People live in there vans and convert them its a thing as well. I am pretty sure most of them did not tell the insurance company.
Let me google that for you
Josiahdr is offline   Reply With Quote
Old 05-16-2016, 07:38 AM   #10
skoolie_n00bie's Avatar
Coachwork: Ward
Engine: Navistar 5.9 Diesel
Rated Cap: A butt-load...
Inside, "passenger" rear corner, under the bed frame.
Less plumbing, not having to deal with outside temp., balance weight out with a/c and people (all that is on the driver side).
n00b build > http://www.skoolie.net/forums/f27/th...ily-10122.html
Not my fault if anything I post results in someone losing a finger...
Errare humanum est, perseverare diabolicum
skoolie_n00bie is offline   Reply With Quote
