Old 07-29-2019, 10:23 PM   #1
Coachwork: International Harvester
Chassis: S1753
Engine: V8 6.9L
AC Removal
I Have 3 AC units on top of My skoolie.I Plan To Put solar panels and a roof deck in their place. Is there a specific way I should remove them??
NfiniteMile is offline   Reply With Quote
Old 07-30-2019, 06:32 AM   #2
are they engine driven AC units or camper style A/C units?
if they are camper style you should just be able to pull them off.. if they are engine driven with the skirt moiunt condensers, you need to evacuate the freon first, then you can unbolt them.. take them down nicely and someone here on skoolie may take them off your hands (esp if they are engine driven)..
Old 07-30-2019, 06:50 AM   #3
HazMatt's Avatar
Chassis: IH 3800, 8 window
[emoji848] hmmm... I wonder who might do that... [emoji6]
Old 07-30-2019, 07:52 AM   #4
Chassis: S1753
Engine: V8 6.9L
I believe they are operated by the generator that’s in the back. How do I find out exactly Tho?
Old 07-30-2019, 08:08 AM   #5
yep those are camper AC's, if they work you may be able to use one or two in your build for parked A/C, or sell them / give them to other skoolies that may want those.. there should be a 120 volt wire going to each one from the generator.. be careful to disconnect the wires at the panel / genny side so they dont cause a hazard when using the generator.. otherwise they are self contained and you can take them off.
Old 07-30-2019, 08:09 AM   #6
Nice classic Ward High headroom!!
