Old 04-26-2017, 01:40 PM   #1
Chassis: B600, 545 Allison Auto
Engine: Cummings Dimple Block 12Cyl.
Rated Cap: 70
Best Gas 4 burner stove and Oven
Hi Guys
Please can anyone recommend a good half height 4 burner gas 'cooker' and oven?
I have seen these half height, but full width stoves used on Youtube conversion videos (bus life NZ etc.)
So you get a 4 ring stove and oven but storage underneath.
but google can't find them...
Any and all info would be wonderful
Thank you!
Howard
HJS26 is offline   Reply With Quote
Old 04-26-2017, 02:07 PM   #2
Robin97396's Avatar
That's called a drop in stove, because it's supported by cabinetry. Not very popular anymore but they are still sold.
https://www.lowes.com/pl/Drop-in-ele...ces/4294715782
30 Inch Drop In Range | Sears Outlet
Drop-in - Electric Ranges - Ranges - Cooking - *The Home Depot
Robin
Nobody's Business
Old 04-26-2017, 02:19 PM   #3
Rated Cap: 70
Hi Robin
many thanks!
I am looking for a Propane system - Thank you
I will now google with the correct terminology...
Thanks Again!!
Howard
Old 04-26-2017, 02:24 PM   #4
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Could go with 2 of these-
https://www.amazon.com/Flame-King-YS.../dp/B01D42QH2U
Or one of these
http://www.campingworld.com/shopping...lp-stove/79821
Roll Your Own Build Thread
Old 04-26-2017, 04:18 PM   #5
Rated Cap: Your mom +1
Suburban is a pretty standard rv appliance manufacturer. here's their 3 burner w oven. 3 burner seems to be the most common... Atwood is another manufacturer with similar products...
Suburban 22" Black 3-Burner Range - Ranges - Ranges & Cooktops - RV Appliances
Old 04-26-2017, 04:33 PM   #6
Robin97396's Avatar
Craigslist usually has RV appliances for sale taken from crashed RVs.
Robin
Nobody's Business
Old 04-26-2017, 04:40 PM   #7
craigslist is a great resource, just make sure if you buy from a wrecked or salvaged rv you test, then re-test, and test again for leaks at any connections and in the appliance supply lines themselves... Even if it looks good on the outside, stress from a crash could create tiny tears in the lines or weak spots.
Old 06-21-2017, 01:03 PM   #8
Brewerbob's Avatar
Engine: 8.3L Cummins ISC 260hp, AT643, 4.44 rear
I'm going to put this here so I can find it later. Nowhere near needing a stove yet but I want a diesel oven.
https://www.fisheriessupply.com/dick...tove-with-oven
Brewerbob is online now   Reply With Quote
Old 06-21-2017, 01:41 PM   #9
Brewerbob's Avatar
Probably don't need to since it's from the same website but I'm going to throw this on there too.
https://www.fisheriessupply.com/dick...-diesel-heater
Old 06-21-2017, 02:18 PM   #10
Robin97396's Avatar
You wouldn't prefer to use a Webasto coolant heater, for a combination of engine warming capability and cabin heat?
Robin
Nobody's Business
