I bought a Frigidaire from Lowe's. Think it is 4.7 cu ft. 110 volt, single door, with a small freezer compartment inside. Door is lockable. Test usage measured with kill a watt meter
320 watts in 24 hours starting with fridge at room temperture
75 degrees up to upper 80's in bus at time of test
opened the fridge a handful of times, not as many as likely in real use though
very quiet
I am by no means saying this is the best, just saying what I have found, and am using.
