Old 09-24-2019, 07:39 PM   #1
Dustynyc's Avatar
Chassis: 48706
Engine: Cat3126/AD2000
Rated Cap: 28
Can I move skirt Condensers?
Hi all. My bus came with 2 engine driven ac systems, 1 working better than the other, but both work. My bus is 29’ long and the condensers occupy 7’ on each side behind the rear wheels. Inside, there are 2 large returns, and ductwork running front to back on both sides above the windows.
My initial thought was to strip it all out to gain the space - inside and beneath, however I’ve read a bunch of threads on the subject and am reconsidering that approach.
Can I move both condensers into one skirt cavity? I think I know the answer, but hey, maybe someone has done it and had success.
Can I move them to the roof?
More likely, I’m going to remove one of the 2 systems and rework the ductwork to feed just the travel seating area of the bus. Perhaps a few fans can be used to keep the cooled air up front. Look for the the removed system in the ‘For Sale’ section next spring. It’ll be reasonably priced.
Dustynyc is offline   Reply With Quote
