Old 10-16-2017, 10:32 AM   #1
Pygmy Yeti's Avatar
Year: '91
Engine: 7.3
Rated Cap: 71
Ceiling Insulation
Has anyone used the injected spray foam insulation? Drilling a few small holes into the ceiling and injecting the insulation seems to good to be true. What am I missing? I really like the idea of not messing with removing the inner skin of the ceiling. Structural integrity and all that. Any feedback is welcome.
Pygmy Yeti is offline   Reply With Quote
Old 10-16-2017, 12:08 PM   #2
Chassis: Saf-T-Liner MVP ER
You are missing the fact that the space is filled with elderly batt insulation which has to be removed.
Steve Bracken
Build Thread
Twigg is online now   Reply With Quote
Old 10-16-2017, 01:08 PM   #3
Over the past couple years I have given this some thought and have a couple questions.
1. If there are no leaks in the roof and the old insulation is dry, why would it need to be removed?
2. If the old insulation were left in place, would the force of the expanding foam be sufficient to compress it, or would the foam mix with the old insulation? Where would be the harm?
3. If it were necessary to remove the old insulation, why not cut in an access hole and install a cover panel when done. This could be done by cutting a 10 X 10 in. square hole between sets of ribs in the ceiling, and pulling the old insulation out using a straightened metal coat hanger having a hook bent into one end. Try to plan your acce4ss holes in places where they wouldn't be to obvious. These 10" access holes would also allow more room for the spray nozzle tube to ensure a fuller more complete coverage. Cover the 10X10 hole with a piece of 11 X 11 in. material metal or plastic ... then paint the ceiling.
4. I am curious if there might be commercial businesses who could do this for you.
It the ceiling panels do lend a bit of structural support you won't disturb anything by cutting in a couple access holes. This could be a time and material saver, at least you wouldn't have to remove the entire ceiling.
Make sure that you use a closed cell foam and NOT open cell foam like great stuff. I see Hilte has a good product and a couple different length foam guns.
I don't mix religion and skoolies
Insulation Fanatics Suck
Bye.
Tedd is offline   Reply With Quote
Old 10-16-2017, 03:25 PM   #4
Pygmy Yeti's Avatar
Year: '91
Engine: 7.3
Rated Cap: 71
I would think the expanding foam would compress the old insulation down to almost nothing. I think an experiment in a small clear box is in order. I bet I could drill a few small holes and be good.
Old 10-16-2017, 03:29 PM   #5
Rusty's Avatar
Engine: 5.9L Cummins
Rated Cap: '00
In theory, yes. In practice, no. Foam needs to be trimmed after spray, if it was confined in a space, you could turn a Blue Bird into a Crown. Poof !
What I do when nothing is on tv... : My Nemesis
Old 10-16-2017, 04:17 PM   #6
Injecting into a void is a real thing, but it's a skilled operation. In theory there is no real reason why this couldn't be done, but if too much catalyst is added the thin ceiling could end up bulging down.
It's an attractive idea, if it worked.
Steve Bracken
Build Thread
Old 10-16-2017, 04:22 PM   #7
1. You can't judge the condition of the old batts, without seeing them.
2. Probably, and probably little harm if the batt is still in place and uniform. Likelihood of the foam pooling would be high as it needs to flow.
3. Would be possible
4. All I can suggest is that you find an expert in foam injection, and ask them if it is possible, and at what cost.
Let us know because it's an interesting idea.
Steve Bracken
Build Thread
Old 10-16-2017, 04:44 PM   #8
Poof? What does this "poof" mean?
Poof as in mixing closed cell foam with old insulation batts there is a possibility of a fire? Or something worse?
Also, why would expanding foam need trimming after being injected into a closed space?
Bye.
Old 10-16-2017, 04:49 PM   #9
He means that the roof and ceiling could bulge out.
Steve Bracken
Build Thread
Old 10-16-2017, 04:54 PM   #10
It wouldn't need trimming if you knew exactly how much to use. I think the point being made is that the idea is technically possible, but your typical DIY foam insulation user doesn't have the expertise to gauge the exact empty space and know how much uncured foam to inject. This would be particularly difficult with an unknown quantity of batting already in place. If too much was used, it could wind up pushing against the sheet metal and deforming sections of the ceiling.
lucasd is offline   Reply With Quote
