10-16-2017, 09:32 AM
Year: '91
Engine: 7.3
Rated Cap: 71
Ceiling Insulation
Has anyone used the injected spray foam insulation? Drilling a few small holes into the ceiling and injecting the insulation seems to good to be true. What am I missing? I really like the idea of not messing with removing the inner skin of the ceiling. Structural integrity and all that. Any feedback is welcome.
10-16-2017, 11:08 AM
Chassis: Saf-T-Liner MVP ER
You are missing the fact that the space is filled with elderly batt insulation which has to be removed.
10-16-2017, 12:08 PM
Over the past couple years I have given this some thought and have a couple questions.
1. If there are no leaks in the roof and the old insulation is dry, why would it need to be removed?
2. If the old insulation were left in place, would the force of the expanding foam be sufficient to compress it, or would the foam mix with the old insulation? Where would be the harm?
3. If it were necessary to remove the old insulation, why not cut in an access hole and install a cover panel when done. This could be done by cutting a 10 X 10 in. square hole between sets of ribs in the ceiling, and pulling the old insulation out using a straightened metal coat hanger having a hook bent into one end. Try to plan your acce4ss holes in places where they wouldn't be to obvious. These 10" access holes would also allow more room for the spray nozzle tube to ensure a fuller more complete coverage. Cover the 10X10 hole with a piece of 11 X 11 in. material metal or plastic ... then paint the ceiling.
4. I am curious if there might be commercial businesses who could do this for you.
It the ceiling panels do lend a bit of structural support you won't disturb anything by cutting in a couple access holes. This could be a time and material saver, at least you wouldn't have to remove the entire ceiling.
Make sure that you use a closed cell foam and NOT open cell foam like great stuff. I see Hilte has a good product and a couple different length foam guns.
10-16-2017, 02:25 PM
Year: '91
Engine: 7.3
Rated Cap: 71
I would think the expanding foam would compress the old insulation down to almost nothing. I think an experiment in a small clear box is in order. I bet I could drill a few small holes and be good.
10-16-2017, 02:29 PM
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
In theory, yes. In practice, no. Foam needs to be trimmed after spray, if it was confined in a space, you could turn a Blue Bird into a Crown. Poof !
10-16-2017, 03:17 PM
Injecting into a void is a real thing, but it's a skilled operation. In theory there is no real reason why this couldn't be done, but if too much catalyst is added the thin ceiling could end up bulging down.
It's an attractive idea, if it worked.
10-16-2017, 03:22 PM
1. You can't judge the condition of the old batts, without seeing them.
2. Probably, and probably little harm if the batt is still in place and uniform. Likelihood of the foam pooling would be high as it needs to flow.
3. Would be possible
4. All I can suggest is that you find an expert in foam injection, and ask them if it is possible, and at what cost.
Let us know because it's an interesting idea.
10-16-2017, 03:44 PM
Poof? What does this "poof" mean?
Poof as in mixing closed cell foam with old insulation batts there is a possibility of a fire? Or something worse?
Also, why would expanding foam need trimming after being injected into a closed space?
10-16-2017, 03:49 PM
He means that the roof and ceiling could bulge out.
10-16-2017, 03:54 PM
It wouldn't need trimming if you knew exactly how much to use. I think the point being made is that the idea is technically possible, but your typical DIY foam insulation user doesn't have the expertise to gauge the exact empty space and know how much uncured foam to inject. This would be particularly difficult with an unknown quantity of batting already in place. If too much was used, it could wind up pushing against the sheet metal and deforming sections of the ceiling.
10-16-2017, 04:24 PM
Unless you (we) can find somebody who has done just that ... I guess an experiment to check rate of expansion would be in order.
I think bigger might be better than smaller.
10-16-2017, 04:26 PM
I had no idea that this stuff could expand with that much force.
10-16-2017, 04:37 PM
This stuff, injected wrongly, can burst brick walls apart
10-16-2017, 04:46 PM
Traveling
Rated Cap: '00
Gives me an idea for a quick-:n-dirty bay window in my bus...
10-16-2017, 05:06 PM
Traveling
Rated Cap: '00
There are different formulations- expanding and non-expanding.
People use the expanding stuff next to window frames and they bow-in. Window manufacturers won't honor warranty.
10-16-2017, 05:19 PM
Year: '91
Engine: 7.3
Rated Cap: 71
Maybe if each void had two holes drilled. One for injecting and the other for overage and expansion. I will definitely be calling USA Insulation to question them about this. If they can do it behind drywall without bulging it, they can do steel. You can also stick a plumbers camera in to have a look first to determine the amount and condition of the original insulation. That might help when th calculating.
10-16-2017, 05:20 PM
Look at Mudda Earth's bulging areas, the spray foam!
10-16-2017, 06:07 PM
Year: '91
Engine: 7.3
Rated Cap: 71
At the 1:50 mark, they show adding the foam with the old insulation left in. Very interesting. I'm calling these guys tomorrow. If there are no problems, I am certainly going this route.
10-17-2017, 11:36 AM
[QUOTE=Pygmy Yeti;229655]At the 1:50 mark, they show adding the foam with the old insulation left in. Very interesting. I'm calling these guys tomorrow. If there are no problems, I am certainly going this route. /QUOTE]
Neat vid. This stuff has a lot going for it. From the vid it looks like the foam would collapse and encapsulate the existing batts of insulation just fine.
Make sure to tell them that the roof and ceiling material is nearly paper thin, not very rigid and non supported areas can be as much as 36 ins. across.
And try to get an idea of costs.
10-17-2017, 11:37 AM
Got a link?
