Re: Cheap All-In-One Kitchen
I went back with the gf and took a look. no price tag, hunted down an employee and got them to price scan it.. Get this... $40 regular $120!! so YOINK! i took her home.
I set it up inside the living room and the top of the top rack is 6 feet tall!! its kinda on the flimsy side (20lbs per section max) so it would need to be re-enforced to the walls to keep it from moving when in transit. the main part has the sink in it, its a double sink, plastic flexible stuff for sink bottoms though.. I suppose it could be made into real sinks but they do for what they do, the water pump used 3 D cells, not included, and my pump wasnt made right and is broken, i jerry rigged it to go and it moves about a full glass in 3 seconds when going full speed. the sinks also have rubber plugs and the tubes just run down into a collapsible water jug although a 5 gallon pail would work just as well.
that shelf up there neatly folds down, dont hold much but guess it could hold seasonings etc if you make a rail for it to hold stuff
the top top part with the hooks for all the ladles and the side sticking out parts is cool if you got stuff to hand from there, it has lots of spots for those S hooks like tarp straps use.
the left side has a place for a propane burner stove part to sit in and has a grill on top of it, not bad at all, has to connect to the main part to stand because it only has one side with legs. bottle not included but there is a stand for the bottle to.
right side is just more counter top and that canvas food shelter. I suppose it could keep most varmints out of it but not bear proof lol. once again it only has legs on far right side and must hook onto the center part for its stability.
also under the sinks, and at the bottom of the stove side there is metal racks that clip into place and provide additional stability to the whole thing.
Also the feets! they all have rubber feetings that you can drive the large yellow tent pegs through to attach to ground. they are also flat at the bottom so you could also use 3 good sided screws to mount them to your floor.
bottom end, it look very good for when you're parked but when you are on the move I think it might be a rattle trap... and needs to be securely fastened into place.
