Old 10-29-2018, 11:48 AM   #1
Year: 2006
Chassis: International IC RE300
Engine: International 7.6L diesel
Rated Cap: 33,000
CheAp insulation
My buddy has this insulation he said is r22. He said he’ll sell it to me really cheap. Don’t know much about insulation but can anyone tell me if this is good. Not even sure what type of insulation it is. Looks like metallic on outside and maybe foamish in the middle . I’ll post pics
B35A2F68-2307-4FDE-94FA-CF0084D6ABB8.jpg   730F5C53-A2DE-4250-82BE-4AC0DF0D7808.jpg
Saucenbach is offline   Reply With Quote
Old 10-29-2018, 12:30 PM   #2
bus-bro's Avatar
Engine: 3208 na boat anchor
No 1/2 inch foam board is R22. Polyiso board is about R6 per inch.
Old 10-29-2018, 12:59 PM   #3
Year: 2006
Rated Cap: 33,000
Ok. Thanks. Still gonna get some since it’s so cheap. But what are some good options for high grade insulation that would be good for walls and ceiling. Also, what good for floor insulation?
Old 10-29-2018, 05:46 PM   #4
bus-bro's Avatar
If the price is right, go for it. As that looks to be polyiso board 2 layers would be about R6.
On my floor I used 1" pink polystyrene boards. It's loads up to 15 pounds per inch, so I put 3/4" tongue and groove plywood on top using no framing. Worked out well, the floor doesn't feel cold though that would only be about R3.
Old 10-29-2018, 06:51 PM   #5
Chassis: Bluebird
Engine: 5.9 Cummins/Allison
Rated Cap: 74
I used 1.5" Foamular on the floor covered with Drimax (slightly less expensive version of Advantech)3/4" no framing floor is solid as a bowling alley and is warranted to be waterproof for 500 days.I will never know will I? I also used 1.5" Foamular on ceiling and in wall voids created by roof lift. Then covered the walls with 2 layers of 1/2" foamular which got everything fairly smooth
and even. next project tongue and groove ceiling and bead board walls.
Gdog 5651 is offline   Reply With Quote
ceiling insulation, insulating, insulation, wall insulation
