Old 04-06-2011, 07:19 PM   #1
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Re: Floor Heater
The water lines come from the engine and have antifreeze in them. Those valves will shut off the water both from and to, closing them will allow you to remove the heater. Wire goes to the fan. If you are not going to put the heater back in, I recommend you plug them some way other than just those valves, they are easily bumped and opened. You would loose your antifreeze. They can be hooked together to close the loop again, but if it were me I would completely remove them.
Old 04-07-2011, 06:30 PM   #2
Chassis: AARE
Re: Floor Heater
You do not need to close the loop, they can just be plugged. If you aren't going to ever need heat in the rear, I would plug them at the engine and tear out the whole thing. At the engine you can either cut the hose and stick a plug in, screw out the fitting and screw in a plug (if it has that kind), or just make a small loop from one to the other. If you do any of that remember, you will have to drain the coolant to do it. (not onto the ground coolant is poison)
coolant still needs to flow through
It doesn't, unless there is another heater that it is supplying. Without seeing it, I would guess there are some "Ts" somewhere that go to the front heater/defroster
I'm sure the small "tube" is just the electrical wire to the heater fan, probably inside of some sort of insulation.
Old 04-08-2011, 09:30 AM   #3
Diesel Dan's Avatar
Engine: DT466/AT545
Re: Floor Heater
I agree with somewhereinusa. If you will be removing the heater, then best to eliminate that whole coolant loop. Trace it back to it's source. Does it go back to another heater or straight to the engine? In either case, close the loop as close to the engine as you can, or eliminate the loop altogether by eliminating the "T" it feeds off of and replace that "T" with a straight connector to continue the primary loop it came off of. Most heater loops are T'd off of another primary loop, but if you remove it directly from the engine, I think it would be best to at least create a short loop that connects the engine coolant output back to the return. Hope that makes sense...
Gallery:
Conversion Thread:
viewtopic.php?t=4959
Old 06-25-2014, 11:48 AM   #4
BruceAlmighty's Avatar
Coachwork: Chevrolet
Re: Floor Heater
This kind of thing is EXACTLY why I joined this message board. I know this is a really old message. Anyone else dealing with removing the old floor heater? I removed it...with a machete. And then had to clean up the coolant. Right now, trying to figure how to trace the hoses back to their origin so I can cap them/reroute them.
"Action expresses priorities." -- Gandhi
BruceAlmighty is offline   Reply With Quote
Old 06-26-2014, 08:45 AM   #5
Chassis: AARE
Re: Floor Heater
What kind of bus do you have? It helps if we know. Almost everything that is built on a large truck chassis (full size buses) will have shut off valves on the engine. One will be near the front of the engine, the other probably near the rear. Water flows out the front one through the heaters and back in the rear one. If you close the valves you will have no heat or defrost. The heaters, if more than one will be in a loop. A rear engine bus will have heater hoses running all the way to the front. If you want to take out the rear heaters you need to put a pipe in to connect the hoses where you take out the rear heaters. If you have a front engine you can simply run a hose from one valve to the inlet of the heater and another hose from the other heater outlet to the other valve on the engine. Everything else can be taken out.
heater claydbal Heating, Cooling and Appliances 1 08-10-2014 07:00 AM
Heater???? Bureau602 Conversion Tutorials and How-to's 12 07-03-2014 09:57 PM
DIY Heater for a Small Space: pulse jet heater lornaschinske Everything Else | General Skoolie Discussions 8 07-15-2012 08:54 PM
Mr. Heater propane heater glock17 Conversion General Discussions 15 10-21-2007 08:59 AM
Need rear heater glock17 Classifieds | Buy, Sell, Swap 3 10-26-2005 09:42 AM
