Old 05-15-2017, 02:58 PM   #41
Brewerbob's Avatar
Engine: 8.3L Cummins ISC 260hp, AT643, 4.44 rear
Originally Posted by somewhereinusa View Post
It is a closed loop. It's basically built like an automotive cooling system. The gray tank is the reservoir if you look closely there is an automotive radiator cap on top of it. That is where the fill is. In order to get that cap higher than anything else the tank needs to be that high. The swing out is to make it easier. The sprayer is just a tank like the overflow on your car. I had no idea how much if any it would be used so I made it big. In actuality I don't think it has ever changed.
Ah, ok thx. I thought the gray was just an arm and you were OCD in your design. That arm doesn't need to be anywhere near that large to support a bug sprayer unless he's using liquid lead.
I've got a custom cooling system in my FrankeinB (1st gen RX-7 with an RX-8 drive train). Same thing with the air separator.
What about the metal around your pex; just flashing or is it AL sheet/plate?
Old 05-15-2017, 03:03 PM   #42
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Rated Cap: Her, me and Molly
Originally Posted by Brewerbob View Post
What am I seeing here? My bus with the kiddie seats in it but no kiddies was 22060 I think. The bus minus the seats, rubber mat floor, and plywood is sitting at 20600. I have NOT removed the interior skins nor windows. Nor have I added new sheet metal for a roof raise. An extra 2,000 sounds a bit much but I don't have a roof rack, AC, nor interior luggage rack.
Have you done anything to try to level load the bus more left to right? You're within 1.5% of front/rear of what you started with. I haven't axle weighed mine much less corner weighed.
The diagram on the left is what it weighed when I bought it. I filled the fuel tanks and weighed it at the truck stop. The figure on the right was done at a bus rally with wheel scales. The difference on the rear axle surprised me since my fresh water tanks are in the center and my gray tanks are the same size and equal on both sides. Basically my gray and black tanks were empty at that weigh. Fresh tanks were full so there is 800 lbs right there. The different things are refrigerator, black tank and computers and printers are on the left. Heavy things on the right are microwave and my toolbox.
Since that weigh I've added my diesel generator to right side in engine compartment and mini split AC. The condensor for rear air is on left. The rest of the AC is centered.
I'm not really concerned about that difference in the rear, heck 6 more kids on the left could make that much difference. I'm well within the axle weight limits.
Old 05-15-2017, 03:07 PM   #43
Chassis: AARE
It's made for that purpose. Using PEX Tubing Heat Transfer Plates under the floor for Radiant Heating
Old 05-15-2017, 03:20 PM   #44
Brewerbob's Avatar
Another one you have a GVWR of 36000 or 38000. My data plate says 33,000. Wonder if there's any difference in suspension and the like.
Since gutting the bus and losing 2k I was curious what I'd be putting back in for weight. Did you keep your interior metal ceiling? There's a little weight there, window frames, and wall skins. Not enough to make up for the additions but another 1,000 lbs I'm guessing. Not that I'm trying to stay under starting weight. I'm not anywhere near my gross either. But it takes fuel to move weight so the less the better.
Old 05-15-2017, 03:28 PM   #45
Brewerbob's Avatar
What the hell man?!!? You've got all this homemade stuff and you can't bend a little metal flashing on your own? Some C channel ripped with a pair of horizontal cutters and TIGed to some AL flanges.
How much was the fancy flashing?
Old 05-15-2017, 04:00 PM   #46
Chassis: AARE
Box of 100 was less than $100, some things just aren't worth the hassle. Time better spent doing something else.
Old 05-17-2017, 02:25 PM   #47
Brewerbob's Avatar
Oh I figured as much but couldn't pass up the chance to bust your balls about it.
Tho, ... your answer is going to lead to another 37 questions!! How long is a piece and what gauge is it? Is it real metal or just tin-foil??? AL ain't cheap so sounds fishy.
Old 05-17-2017, 03:50 PM   #48
Chassis: AARE
Here's a link to the stuff.
2ft x 4" wide Aluminum Radiant Heat Transfer Plates for 1/2" PEX (100/box) - PexUniverse
So, you're a govment worker? Am I paying you to bust my balls?
Old 05-17-2017, 04:11 PM   #49
Brewerbob's Avatar
Far worse. I'm a contractor on a govie project. That means you're paying me twice as much to bust your balls. I hope you filed your taxes on time.
Old 05-17-2017, 04:13 PM   #50
Brewerbob's Avatar
~27 gauge. Interesting.
