Old 07-11-2018, 07:03 PM   #1
Generator size
Ok Peeps, got a new mach 15 ac unit for my short bus, should i do one 3500 kw,or 2 smaller generators?
Hott76 is offline   Reply With Quote
Old 07-11-2018, 07:23 PM   #2
Thomas1985's Avatar
Chassis: GMC G3500 Vandura
Engine: V-8 5.7L Gas
Here is some general information:
https://www.steadypower.com/pages.php?pageid=133
Really if you want to run a 15,000 btu unit and anything else at the same time you should go with the biggest generator you can afford. It will be more efficient. 5000 W + would be better. 3500 barely meets the needs of starting it
- Thomas
The Daily Driver Bus Build
Thomas1985 is offline   Reply With Quote
Old 07-11-2018, 08:19 PM   #3
Thomas1985's Avatar
I have The EU3000iS and it will run for up to 20 hours on a single tank of 3.4 gals of gas but only if it's not running a real heavy load.
You can get the smaller 2000 versions and connect two of them together but they only hold 1 gallon and run up to 8 hours. That means you might not make it through an entire night before needing to refill.
At this point I wish I would have got the 7000.
I found a 13,500 BTU Coleman air conditioner called a Power saver that runs on 10 amps that will work fine for my generator.
- Thomas
Old 07-12-2018, 06:19 AM   #4
Thankyou this is helpful, i already have the 15000 ac, do you know anything about the generator that runs on propane and gas, i thought propane would be easier to transprt.
