Old 08-29-2015, 10:40 AM   #21
Any climate controlled structure needs the air turned over regularly to avoid a host of problems including moisture build up. These days, small 12v computer fans are a great, low energy option for cycling the air. Like I said, it doesn't take much, but bringing in fresh air and removing stale, moist air is critical to maintaining both comfort & safety.
Old 08-29-2015, 08:47 PM   #22
Engine: 190hp 5.9 Cummins
If your in the Canadian winters, you best have some serious $$ for insulation if your going to use propane.
I feel propane should only be used as a last resort due to the dangers. Electricity is best in small spaces like a bus if your in a place that has a electrical connection.
If your off grid, and no one else is close, a coal burning stove that also uses wood is hard to beat. Each ton of coal cost $50 and had the same BTU as 6 cords of birch fire wood. Last year I burned just under 2 tons ($90 worth) all winter in my bus shed. That was all winter, and my bus shed has no insulation on the floor, and holes that leak air.
Old 08-30-2015, 10:59 PM   #23
A wood stove is definitely in the long term plan, I grew up in a cabin that only had an airtight stove and a cookstove. But when the fire burns put in the middle of the night, it's dang cold waking up. So a second heat source that kicks in or can be left unattended while I'm out working is key.
Longrun is offline   Reply With Quote
Old 08-31-2015, 02:16 AM   #24
With coal, the fire burning out is not a issue.
Coal will last 12 to 24 hours between loading's.
Old 08-31-2015, 09:10 AM   #25
I do wish coal was more readily available throughout more of the US for the reasons Nat stated. Much denser energy source with a lot less cleanup. A dual fuel coal/wood stove would be my first choice (wood as a back up).
Old 08-31-2015, 10:46 AM   #26
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
Hardware store I used to work at in High School (now since closed) used to heat with coal in the winter- two stoves double stacked in the main part, one in the other part. Unless it was really cold, one stove was sufficient, otherwise all three were lit.
Captain Obvious on deviantArt
