Old 09-19-2006, 08:43 AM   #1
phillbus914's Avatar
HEAT
So Winter is comming up and I'm starting to think about heating options for my bus. I was at Menards last night and seen one of these 18,000 btu portable heaters on sale for $99 - I wrote the specs down and looked around online and see them going for $125 + shipping on most sites. So it seems like a good deal.
http://www2.northerntool.com/product-1/200307957.htm
I like the idea of one of these rather than a wall mounted unit because 95% of the time I really dont need a heater in the bus.
Anyone use something like this to heat their bus?
It claims to heat 400 sq/ft. which seems like it would be enough to keep the bus warm. But busses dont really hold heat that well. It also can run off 2, 1lb cyl's or a 20lb tank (same as a grill tank?) which I usually have with me on a trip anyway.
What do you guys think?
My Old Bus :(
Old 09-19-2006, 02:14 PM   #2
the_experience03's Avatar
I've been kicking around the idea of using hydronic baseboard heat in my bus. It's unobtrusive and easy to do. I'll put valves on my radiator totally isolating it from engine cooling system so that 100% of the coolant heat goes through the system. That along with the weather front on the motor to keep it from being air cooled as much as possible should help make hydronic heat work. Even with basebaords on both sides for the whole length of the bus, I'm prepared to have to also install a head exchanger coil with some forced air heat as well. I just like that hydroic heat makes it easy to use an electric boiler, propane boiler, the engine, even solar to heat the bus.
Old 09-19-2006, 03:15 PM   #3
I have the stock rear heater core & fans in my bus which do a fine job when the bus is running. I was thinking of something to use when camping - mainly overnight. We camped in Canada last May & it was down in the 30's at night - I froze my ass off. I think something like this portable heater would work great for a situation like that.
I could have left my engine running all night but I like the idea of an indoor approved, portable heater better.
My Old Bus :(
Old 09-19-2006, 03:17 PM   #4
What about a boiler like Jason runs for the jacuzzi? Those portable heaters are great, but cost $$$ to run.
Old 09-19-2006, 06:41 PM   #5
wtd
wtd's Avatar
Year: 1982
Coachwork: Thomas TransitLiner
I used the smaller one of these - 9000 btu's and just holds 1 one pound bottle instead of two.
It would be better if it had a fan in it to push the hot air around - seemed as though if you were 6" from it it would catch your pants on fire - if a foot away it was like it wasn't even there. This winter I'll just try putting a fan behind it or something. It did heat the ceiling right over itself very well.
Used about one bottle a night as I remember on the high setting. I got an adapter and hose and ran it off of a 20 lb. cylinder, as those little ones get kinda pricey after a while.
I've wondered if those Olympian wave (I think that's what they're called) ones are any better? Anybody use one of those? Everyone speaks well of them, but they don't appear to be any different than the 'Buddy" heaters, just more expensive.
The Rolling Motel Room
Where DIY meets WTF
wtd is offline   Reply With Quote
Old 09-19-2006, 08:18 PM   #6
oldog12's Avatar
Don't you guys worry a little about carbon monoxide poisining? I too am planning to put in hydronic heating in my bus. I figure on using a dedicated water heater (suburban 10 gal DSI) for the heat source. I just have to figure out the manifold layout as well as the mechanics of it all. Hope it works...
oldog12 is offline   Reply With Quote
Old 09-19-2006, 08:53 PM   #7
GoneCamping's Avatar
I've lived in my Travel Trailer for the last 2 winters, and hope to be in the bus this winter. Even though the TT had a propane furnace (one that is properly exhausted to the outside) I rarely used it, only on occassion when I wanted some very fast heat. For regular heating, I used one 36" baseboard style electric space heater, and only used it on the low/600W setting. If it got really cold (we had a few nights down into the teens) I had a second fan forced electric space heater, I also would run it only on the low/700w setting. The two of them together used less power than a single unit on full power/1500w setting...I placed them forward and aft in the trailer.
I plan to use the same thing in the bus, but perhaps utilize two of the basebaord units...one in the rear bedroom, the other in the living room. I just feel much safer with the electric heat than the propane due to carbon Monoxide. I also get electricity supplied in my monthly rent here at the campground, propane I have to pay for!!
Be that as it may, the fifth wheel donor trailer had a nice 18,000btu ducted furnace in it...not sure if it still works, I don't think it was ever used and looks like it's in really great condition. Even if one or more components are bad, I can buy the parts and pieces as needed. Long story short, I'll have a furnace should the need arise...but still would rather use THEIR electricity than MY propane!!
*Cliff*
...Your home has brake lights
1994 Jeep Grand Cherokee
Chesapeake, Virginia
GoneCamping is offline   Reply With Quote
Old 09-19-2006, 11:05 PM   #8
oldog12's Avatar
Wood stoves.... Hmmmm..... Open flame, dirty, fuel is bulky and relatively expensive, takes up a lot of room, but otherwise I can't really see anything basically wrong with them.
Old 09-20-2006, 01:28 AM   #9
If you have the coin, I think a pellet burner might be the way to go. They are quiet, cheap, and really crank out the BTU's. Unfortunately they are pretty spendy and cumbersome. That's why I still want to go with hydronic heat. It's unotrusive, and inexpensive. I can use the engine to heat the bus or use the secondary boiler to heat the engine. As for carbon monoxide...most new heater have low oxygen shutdowns. The catalytic ones say they are for indoor use right on the package. That combined with a CO detector and all the air leaks the average bus has, and I think you're safe.
Old 09-20-2006, 07:55 AM   #10
Yeah a pellet furnace or even an RV furnace would be the ideal way to go if I had the money. The boiler idea would be nice as I could use it to make hot water too. I'm not to that point with my bus yet... maybe next summer
In the mean time I really like the idea of portable heat like one of these heaters makes. I'm not too worried about the carbon monoxide since these are rated for indoor use and have a low O2 shutoff.
I used a ready heater last winter while I was working on the bus & mann does that stink the bus up, I had to have a few windows open a few inches for ventalation. My main need for this type of heater though it to use while camping on cold nights. Depending on the cost to run it I may also use it while working in the bus in the winter.
Anyone know how many BTU's are needed to keep a bus warm? Would 18,000 be enough? The outside dementions of my bus are 8X34 so Thats less than 272 indoor suare feet. I wonder if a heater rated for 400 would be enough in a drafy, poorly insluated, 16 year old bus.
My Old Bus :(
Old 09-20-2006, 11:55 AM   #11
captainkf's Avatar
Year: 1985
Engine: 366 propane
Rated Cap: 56
When I was working in the service dept at a local RV dealership, a technician who really knew his s**t suggested at least 30,000 btu's. This was for an insulated converion. We were talking about my bus which has about 27' inside. I currently have a "vintage but safe" hydrotherm gravity feed (no fan, no power needed) direct vent 13,000 btu furnace. The coldest it got for us so far camping was 4 degrees celcius. That's pretty cold. The furnace on it's lowest setting still cooked us out. I had to turn it off in the middle of the night.
I would recomend trying to find one of these. Mine came out of a 1972 steury tent trailer. However factory converted vans often have very small and simple furnaces that can be had for very little. The nice thing about a couple of small units is the ability to customize what they are used for or what area's of your bus need more/less heat. They require NO POWER. So if you batteries die, or you have a power problem and it is cold you still have heat. This is a big concern for sub zero camping. If you have no heat, you have frozen pipes . No good. Even still you should have a backup. A stand alone unit like what was discussed earlier seems like a good idea. I would be concerned about CO2 though. I know it has an emergency shutoff, but sometimes backups don't work. Use caution with these things, people die every year because of portable propane heaters.
-Richard
captainkf is offline   Reply With Quote
Old 09-20-2006, 04:06 PM   #12
Here's my current setup, works well, better with a fan in the corner above it. I have the original roof vent that is always open (yes, I lose heat, but it makes me feel better) I also have a CO detector. This is an old photo, the wheelwell is now covered/insulated. The heater was also free.
Brad Davis
79 International Wayne
"Big Blue"
bdavis441 is offline   Reply With Quote
Old 09-21-2006, 01:32 PM   #13
SeanF's Avatar
Chassis: IHC
Engine: Dt360
Rated Cap: 19
We're using a Fatsco "Tiny Tot" solid fuel marine stove.
Shielding details here.
Stove and chimney pipe installation details here and here.
Our coldest overnight temp so far has been just below freezing, and the stove heats the bus just fine. We started burning wood, but it burns very quickly so it's impossible to keep it going overnight. We've experimented with charcoal and it works great. Not the cheapest fuel available, but burns long, predictably, and with very little smoke. (Yes, we have a CO/smoke detector/alarm installed.) The stove was originally made for burning coal & charcoal, so the bottom grate and other parts are built to withstand the higher & prolonged temps of burning those fuels.
Tiny Tot website
We are losing a lot of heat through the front glass and driver's area (flat nose, front-engine). In the next few days we'll make an insulated curtain to hang behind the driver's seat across the width of the interior.
Sean
Bus conversion/info here
SeanF is offline   Reply With Quote
Old 09-21-2006, 01:45 PM   #14
SeanF's Avatar
Chassis: IHC
Engine: Dt360
Rated Cap: 19
Re: Wood?
Originally Posted by convertabus
Anybody know anything about possibly using a wood stove to heat a bus? I've seen it in pictures, but know nothing about the effectiveness, efficiency, or safety.
Safe as using one in a house...if installed & used correctly. Wood is plentiful and can be had for free or nearly so in most parts of the country. If you plan on long-term, remote camping I'd say it's the choice. For shorter-term or occasional use, a propane heater might be the trick.
One distinct advantage to propane is being able to control the amount of heat put out by the appliance. A drawback is that the propane combustion process produces quite a bit of moisture.
Solid-fuel stoves require some practice and definitely more attention. Zero moisture.
Everything has trade-offs - you just have to figure out which ones you're willing to deal with.
Good luck & be safe
Sean
Old 09-21-2006, 02:41 PM   #15
Steve's Avatar
Re: Wood?
Doesn't take but a few minutes to fog up my entire bus if I use the stove.
Old 09-23-2006, 05:06 PM   #16
captainkf's Avatar
Year: 1985
Engine: 366 propane
Rated Cap: 56
I've never had moisture issue with my furnace, only my stove.
-Richard
Old 09-24-2006, 12:46 AM   #17
I like the ease of a vent free propane furnace but the CO issue worries me. I also would not like to wake up to a dripping ceiling from all the moisture.
I plan to use a very small wood stove. I can get pallats for free. I plan to put a storage box underr the bus to store the wood in. Another option would be to use coal. Yeah yeah I know it is messy and dirty. It sure does burn good and long.
busone is offline   Reply With Quote
Old 09-24-2006, 07:32 PM   #18
Coachwork: Ward Genesis
Engine: DT466/MT643
I have 2 systems: a propane space heater (vented outside) which should heat the whole bus pretty well (the driver's area is closed off & I did insulate) if needed. It has a thermostat & needs no electricity, so it's good for boondocking. I'll probably use a small fan to circulate the air when/if I use it. For the road, I have the stock rear heater, which will turn the whole bus into a sauna on high.
I also have my friend's contraption. That's what he calls it, anyway: he built it for me (he said he was bored one weekend ), and it consists of a 1.5 litre VW diesel spinning a big 300A truck altrernator and 2 car A/C compressors. With it running, I can turn a valve to divert the coolant from the small heat exchangers it uses in warm weather to the bus's rear heater, and several baseboards. It uses electricity for the fan & the auxiliary pump, but that's no problem.
I prefer to use the Contraption...propane is bleeping expensive, and red diesel is, well, less expensive.
Jarlaxle
Old 09-19-2007, 12:55 PM   #19
Re: HEAT
Well I returned that Mr Heater to the store because I was not happy with it. I had to wait until this month to return it because it is a seasonal item and they didn't carry them over the summer. I ended buying one of those wall mounted ventless heaters off Craigs list for $40... a lot better than the $160 they cost new.
I rigged up a real cool mounting bracket that can be easily removed when I don't need the heater.
It's pritty simple, the wood is cut to fit in front of the window, and rests on the bottom of the window sill. It's held in place with a piece of scrap metal stair trim, screwed to 2 of the window screws.
when in place the heater hangs from the bracket it came with - which is screwed into the wood.
the whole thing can be removed in seconds. I like that it's easily removable since most of the time I don't need heat in the bus anyway. Plus I can move the whole setup into the garage in the winter or wherever I may need heat.
My next problem was finding the proper hose to hook to my 20lb propane tank from my grill. I finally found the right fittings and hoses yesterday and hooked it all up. I was a little worried because the hose has a much smaller inside diameter than the fittings do.
I tested it out and it seems to work fine though... I only ran the heater for about 30 sec, since it was about 80 in the bus anyway, but it really kicks out some heat. I think I'll use a fan on the counter top next to it to blow the air around more, the ceiling was real warm right above it.
Next issue I need to figure out is where to store the propane tank when I'm using the heater. I was thinking about putting it under the counter but then I remembered that the fridge is in there. Is it dangerous to have the tank sitting in there next to the fridge? I mean the tank/hose shouldn't leak any propane when connected properly.
Should I put forth the effort to fab. a propane tank holder under the bus accessible from outside? I think I probably should but it sounds like such a pain in the ass.
Also I have a CO detector in my house that's removable that I plan to use when using the heater overnight. The heater also has a low O2 shut off, and I plan on cracking a few windows for ventilation.
My Old Bus :(
Old 09-19-2007, 01:12 PM   #20
lapeer20m's Avatar
Re: HEAT
you know me, I am Mr Safety! Here's my thoughts on a simple way to haul the propane cylinder. Making a holder for the tank under the bus is a good idea, but takes a lot of work, crawling on the ground, and makes the tank not accessable while you're inside the bus.
how about a cabinet that is sealed off from the interior of the bus, but has a door on it so you can change the cylinder/turn the gas on or off. If the cabinet was sealed off from the interior living compartment, and had holes drilled in the floor for ventilation it seems like this may be a perfect option. This is what ambulances do with large 0xygen cylinders.
portable a/c - heat leadsled01 Conversion Tutorials and How-to's 3 01-25-2015 05:20 PM
heat vanpeoplx2 Heating, Cooling and Appliances 10 01-14-2011 07:34 AM
What should I use for heat? Diesel Dan Conversion General Discussions 2 10-10-2010 07:54 PM
no heat mfrederick Skoolie Conversion Projects 6 01-11-2010 09:05 PM
I need heat! the_experience03 Conversion General Discussions 8 02-18-2006 08:28 AM
