Old 01-29-2018, 12:34 PM   #1
How do I remove Rear A/C and heater?
I think I want to remove the rear A/C,most of my time will be spend staying in one spot and I think I want to install a Mini Split.
I still want A/C in the cab
It is at least in the way right now as I am trying to gut the Bus and take the paneling out.
How do I take the Rear A/C and Heater out?
thanks
Blue hole is offline   Reply With Quote
Old 02-18-2018, 06:26 PM   #2
You probably need to discharge the refrigerant line first to get all the R134a out. There should be a valve on there somewhere for that purpose. The refrigerant lines should all be contained in that A/C unit (not running throughout the bus).
Once you have that done, it should just be a matter of undoing fasteners and pulling the whole unit off. Looks heavy.
Professionally converting vehicles and making custom furniture with a combined 14 years of mechanical/electrical engineering experience.
https://www.thunderstruck-studios.com/
ThunderstruckStudios is offline   Reply With Quote
