Old 08-14-2012, 06:55 PM   #1
Atridox's Avatar
Engine: Gasoline
inside heat from radiator
Thanks to all for the continued help. There was an air conditioning/heating unit mounted in the rear roof which was all rusted and subsequently removed. There were four black hoses running to it. Two of them were conduits for the radiator fluid (assume for the heat). I dont need air conditioning, but I would like to have some heat in the back. I was thinking about hooking up a small car radiator to the two tubes and mounting the radiator near the roof to generate heat when the valves on the engine are open sending the fluid through the radiator.
1. Anyone have a better idea?
2. Any idea of what radiator would work - do I just go to the auto parts store and see what they have?
Thanks,
Atridox is offline   Reply With Quote
Old 08-14-2012, 07:20 PM   #2
somewhereinusa's Avatar
Chassis: AARE
Engine: 3116 Cat 250hp
Re: inside heat from radiator
It would probably work, but a bit inefficient, putting a heater up high isn't really a good idea since heat rises. A better plan would be to find a rear bus heater. It already has the right size hose connections and one or two fans. You don't say where you are. I've got a couple I'll give away, since I'm not going to use them. Probably local pickup only, shipping would be a bit expensive. I'm in northeastern Indiana.
Dick
Old 08-14-2012, 09:17 PM   #3
bapos's Avatar
Chassis: International Amtran RE
Engine: DT466E/MD3060
Not sure where my post when on this so I will give a shortened version.
I have been thinking about this myself. I wont be in my bus very often when its cold but I may here and there.
If you keep the radiator thoughts you need to find a way to regulate the heat output like the temp adjust you have in a car. In your current setup it will be either on or off. If you just use a radiator you will need to have some way to push or pull air through it. Its a good way to heat while driving but I think idling to warm the water is very inefficent.
Since I am planning on a LP to run my generator (yes I hate ethanol in gas) I will probably pipe in a few outlets in the bus to run some type of stove. So some food for thought.
I agree the mounting of the heater up high would not be a good idea due to heat rising..... unless you move it with a fan or some sort.
Old 08-14-2012, 09:47 PM   #4
lornaschinske's Avatar
Rated Cap: 89
You might want to checkout A Simple RV Hydronic Heating System IF you can find the article. I have it copied down because I tend to lose it online.
Fulltime since 2006
Old 08-14-2012, 10:16 PM   #5
opus's Avatar
Chassis: All-American R/E
Heck, there are enough people here who take heaters out of their buses, just get one of those. Put it on the floor. I would also put a bleed valve on it to get rid of air. That can be a bugger at times.
Old 08-15-2012, 02:05 AM   #6
My furnace is on the floor, as well as the wood stove, etc. However that is really not necessary to have stove mounted on the floor, or a water circulated heat coil like the bus rear heaters. Many garages have heaters mounted up high near the ceiling, and my wild guess is that if a heater or heat duct can be near the top of the room and heat it, one in a bus would work the same way with a fan.
Both my ac units are near the roof, one being in it, and that cools the bus, so i dont think placement is the issue.. i think btu's is.
i also have a couple of rear heaters that i took out.
Old 08-15-2012, 06:51 AM   #7
Chassis: AARE
My point exactly, those heaters usually have big noisy fans, and if you climb a ladder to the ceiling it's HOT up there and at best it's warm down where you work. I've spent the greater part of my life with cold feet in shops. It was also cold laying on a creeper. Didn't get them warm until I bought a building that had the shop on the second floor with a heated lower floor. I hate cold feet, that's why my bus is going to have in floor hot water radiant heat.
Since cold air falls that is the best placement for a cold air source.
Old 08-15-2012, 08:25 PM   #8
Atridox's Avatar
Engine: Gasoline
Dick
Excuse my novice-ness but are you talking about one of the huri-hot unit?. There is one currenlty on ebay
http://www.ebay.com/itm/Hurri-hot-schoo ... 1f&vxp=mtr
There is also this one on ebay:
http://www.ebay.com/itm/New-20-000-BTU- ... 75&vxp=mtr
Would either of these work?
Old 08-15-2012, 08:28 PM   #9
opus's Avatar
Thats a small hurri-hot. Where are you located? I was thinking the floor models.
Old 08-15-2012, 08:38 PM   #10
Atridox's Avatar
Engine: Gasoline
Yes! What you have is what I need. I am in Bowling Green KY. Are those shippable?
Old 08-15-2012, 08:56 PM   #11
Chassis: AARE
I have the same heaters that opus has. Probably a bit pricey to ship, but I'm only four hours north of Bowling Green.
Old 08-15-2012, 09:09 PM   #12
Atridox's Avatar
Engine: Gasoline
May I come get one? I ll be up that way in a few weeks.
T
Old 08-15-2012, 09:20 PM   #13
opus's Avatar
NO! I use mine.
Old 08-15-2012, 09:42 PM   #14
Chassis: AARE
May I come get one?
pm me with details
Radiator reservoir lornaschinske Mechanical and Drivetrains 1 10-04-2011 12:06 AM
Cleaning inside of the bus? KC10Chief Conversion General Discussions 4 02-28-2007 07:20 PM
crown radiator westport_wayne Everything Else | General Skoolie Discussions 1 08-24-2006 11:26 PM
Help! Need a radiator Fan Ralis Mechanical and Drivetrains 10 07-25-2006 01:01 PM
Why me? Radiator trouble! J.B. Classifieds | Buy, Sell, Swap 0 05-05-2004 08:53 AM
