Old 11-24-2016, 09:43 PM   #11
Chassis: B3800 Short bus
Originally Posted by DoubleO7 View Post
Then run the vent straight out thru the wall with a low profile cap outside.
If the propane furnace vents its exhaust with a fan then that could work. If it uses chimney draft then it'll work best going straight up through the roof. The furnace literature should specify.
Old 11-24-2016, 10:17 PM   #12
Carytowncat's Avatar
I am reading while i have a warm fire going in my propane fireplace, also an expensive model i bought on craigslist for craigslist cheap.
I used one of the Thomas metal plates on the rear of the seats and vented it right out the window.
Imgur: The most awesome images on the Internet
Old 11-26-2016, 10:44 AM   #13
Tootalltechie's Avatar
Year: 1974
Chassis: CHEVROLET C60 just under 19700 lbs body#B10353
Engine: 350 ci on propane
Rated Cap: 48
What does the product manual say?
Tootalltechie is offline   Reply With Quote
Old 11-26-2016, 10:49 AM   #14
As I wrote before Vermont Castings does not recommend their products installed in RV or school busses. I appreciate your reply tootletechie, but I am interested not in how to install the fireplace, but getting back to my original post, what you did to install a chimney? and hopefully product recommendations, to make it stealth, do not wish to advertise it is a hippie bus.
Bluespoet is offline   Reply With Quote
Old 11-26-2016, 11:10 AM   #15
Year: 1974
Rated Cap: 48
Does not matter where they say it can or can not be installed. What matters is how it was installed.
JMO
Gordon
IN the fine print it may say if installed in RV it can not be insured. That is why I have a portable wood stove.
Old 11-26-2016, 11:15 AM   #16
JMO
Gordon
I absolutely agree, I do have the manual and also a local distributer, but this is off topic and I really would love to stay on topic.
