Old 09-27-2016, 12:30 PM   #31
Coachwork: AmTrans
Originally Posted by milkmania View Post
Here's Don's back story...
About Us - Four Dog Stove Co
Read the 5 items below the stove:
Three Dog DX Camp Stove - Four Dog Stove Co
He's got some field testing YouTube videos out there... His enthusiasm convinced me that him and his family put their passion in their product!
There's probably some YouTube links at his homepage, but I'm rocking an iPhone
What makes these "tent stoves" vs. regular wood stoves? Are they safe indoors? I noticed it looks like they are just single wall boxes with no lining of any kind. I like the price and functionality though.
WhiteWhale is offline   Reply With Quote
Old 09-27-2016, 01:02 PM   #32
Rated Cap: Your mom +1
A tent stove is going to be a much thinner walled stove. Typically made of sheet metal rather than 1/4"+ steel plate. I looked into using a smaller tent style stove, but found a nice englander pedestal stove locally for less than a hundred bucks. It's waaaay heavier than a tent stove but it's lined with firebrick also. My reasoning was that since it is thicker steel with the brick it will retain heat longer than a thin walled tent stove and it also has the bonus of being an epa listed stove that is approved for install in mobile homes so I guess that adds a little piece of mind. I'm also going to add a secondary burn system to it to produce a cleaner burn. Not sure if a tent stove would hold up to that...
Old 09-27-2016, 01:13 PM   #33
Awesome! Thanks guys
EricW is online now   Reply With Quote
Old 09-28-2016, 05:52 AM   #34
Tootalltechie's Avatar
Year: 1974
Chassis: CHEVROLET C60 just under 19700 lbs body#B10353
Engine: 350 ci on propane
Rated Cap: 48
I use to get slate from old pool tables to use as high temperature soldering table work.
Sent from my SM-T530NU using Tapatalk
Tootalltechie is offline   Reply With Quote
Old 10-11-2016, 04:48 PM   #35
Engine: T444E 7.3
Rated Cap: 64
I'm looking at the small Logwood stove from US Stove. Rated at 900 SqFt and 55000 BTU. How long of a chimney pipe do most people install on the outside of the bus? I was thinking of having a section of pipe that I could remove and replace with a cap for travel. Or would it be better to just penetrate the roof by six to eight inches with the additional height for the cap making it about twelve inches total.
buddyvz is offline   Reply With Quote
Old 10-11-2016, 08:02 PM   #36
superdave's Avatar
Chassis: thomas
Engine: 8.3 cummins
Rated Cap: 11 window
at least 15' total from the stove is best. the less the pipe the less the draft going up.
my build pics
Old 10-12-2016, 10:36 AM   #37
Engine: T444E 7.3
Rated Cap: 64
Thanks Dave, I doesn't seem practical then to install a wood stove in a bus that would be mobile. You would have to remove a significant amount of pipe during each trip. The biggest issue to that would be the supports on a pipe that long.
Old 10-12-2016, 11:05 AM   #38
It takes literally two minutes to pull the pipe and stick a cap in the hole before you're on the road... Just sayin...
Old 10-12-2016, 02:35 PM   #39
Chassis: B3800 Short bus
My chimney is around 8'. While not a perfect install, it works just fine with our small stove. Before opening the wood stove door I open the intake air fully to get it burning as hot as possible to increase draft a bit. If I open it when it's burning cooler I sometimes get a small cloud of smoke wafting out the door.
I used Selkirk's twist-lock pellet stove pipe for the 5' extension on the bus roof. That way it stays on nice and tight and is easy to pop off.
It holds tight enough to stay on when cruising down the road at moderate speeds Not advisable, but sometime you forget about the pre-trip checklist!
You can see more of my woodstove install in my build page, which is posted as my signature.
Old 10-12-2016, 04:12 PM   #40
Engine: T444E 7.3
Rated Cap: 64
Thanks for the reply. Your build page is awesome, so much great information. I like the idea of the twist lock and will check this out.
