Old 11-19-2012, 10:31 AM   #1
Coachwork: GMC
Chassis: Rally
Rated Cap: 10
Installing woodstove in my GMC minibus
So I am looking into installing a woodstove before I move up to Baltimore (not the coldest place in the world, but still pretty cold for living in a moving metal box) and I need some advice. I am looking for a tiny woodstove, would prefer the sardine or the hobbit or something like that but its out of my price range, so considering a stove from four dog, maybe the two dog or 3 dog model. Anyone have any experience with these types of stoves, and would you suggest putting firebrick inside? Will it heat my 13 x 6 bus pretty well? I have a 4 x 4 space to put it in, and basically would like to have 1 1/2 feet on each side and 1 to 1 1/2 feet from the wall. Can I put up something, such as cement board, in order to make it safely fit in these dimensions? What is the risk of carbon monoxide poisoning (I will probably be putting in a detector, but if you have any other advice on how to lessen the risks). How well do these damper? If anyone has any other advice or pictures of the installation of a stove please let me know! Thanks!
-Annie
taran_tella is offline   Reply With Quote
Old 12-24-2012, 01:26 PM   #2
MikeyBskunk's Avatar
Coachwork: Ford
Chassis: Carpenter
Engine: 7.8 New Holland
Re: Installing woodstove in my GMC minibus
i have a wood stove in my bus witch is a 40 footer and it heats it up very nicely. if you keep enough logs going in it can get as hot as u want it to. take a look at my build page for construction ideas, its called ''The Sloth''
Mikey
MikeyBskunk is offline   Reply With Quote
Old 12-24-2012, 09:08 PM   #3
post removed
Shawn C is offline   Reply With Quote
Old 12-25-2012, 09:43 AM   #4
Moderator
crazycal's Avatar
Engine: DT408, AT545
Rated Cap: 23 500 gvw
Originally Posted by Shawn C
Hey Annie, I build woodstoves for ice fishing huts up here in Canada using expired BBQ propane cylinders. If you know somebody that has a welder you can make one of your own and please feel free to use my design if you like it.
-Shawn
Thanks for the offer. That stove looks cool. Are your plans online?
I'm hungry!
You Gotta Let Me Fly
Old 12-25-2012, 10:34 AM   #5
post removed
Old 12-25-2012, 04:50 PM   #6
Moderator
crazycal's Avatar
Thanks. Could you at least post some pictures with some details. That might be helpful for me because if I just wing it I'm afraid of how it would tunn out.
I'm hungry!
When it comes to a woodstove... pictureLOVE Heating, Cooling and Appliances 8 06-14-2014 03:45 PM
Tailgating Minibus Conversion chev49 Short-Bus Conversion Projects 10 08-10-2012 08:16 AM
Got the woodstove in... staggerlee917 Skoolie Conversion Projects 9 10-14-2008 11:28 AM
Full-size schoolie vs. minibus Clueie Everything Else | General Skoolie Discussions 16 10-27-2004 10:09 AM
Installing woodstove in my GMC minibus taran_tella Short-Bus Conversion Projects 0 12-31-1969 07:00 PM
