01-09-2020, 10:13 AM
Chassis: Van
Engine: 5.7L Gas
Insulating the Windows?
Hey All,
I am in the process of planning my bus insulation. I think I am going to go with 1" XPS insulation for the floor and 2" XPS insulation for the ceiling and walls. I would like to keep the bus windows as I like how they look from the outside and don't want to deal with taking out the windows and welding sheet metal over the holes. My question is, can I wall/ insulate over some of the windows on the inside? So the windows would all be visible from the outside but only about half of the internal windows would be visible/ usable from the inside. The others would be covered with insulation and wood siding. I'm assuming I might run into some serious condensation issues due the the covered windows being in contact with insulation? If I left a 1/2" gap between the window and insulation would that help? As you guys can tell I am pretty new to this and learning as I go. Thanks for the help!
BTW I own a 2002 Chevy short bus.
01-09-2020, 10:35 AM
Engine: 8.3 Cummins ISC
Rated Cap: 75
The windows have a bad habit of working themselves open while driving down the road. I would make it so you can easily access the windows if you have to.
Also yes I could see condensation being an issue as well.
01-09-2020, 10:42 AM
I helped a tent out here with his conversion and he had a similar situation. He sound up cutting the 1" blue foam to fit each window and then had them covered in a fabric that matched his interior.
They looked very sharp.
He could pick and choose which windows were covered or not, depending on climate and view.
01-09-2020, 10:44 AM
Chassis: Van
Engine: 5.7L Gas
If I ended up covering these windows I would completely seal them off so they would not be able to be opened. Then again I might want to open them up occasionally to air out any condensation that would occur...
01-09-2020, 10:45 AM
Chassis: Van
Engine: 5.7L Gas
This was the other option I was thinking about. I didn't want to do this because I wouldn't be able to use that space around the windows for a closet/ wall/ whatever. But I guess I could still do this if it looked nice enough!
01-09-2020, 10:46 AM
I'm going to make window inserts out of 2" XPS covered with black fabric (facing the outside) and white fabric (facing the inside), with velcro around the edge to attach to a wood frame around each window (my windows are black so these should not be too obvious from the outside). I'm thinking maybe each insert will have a small pocket on the out side that I can fill with silica gel packets - not sure that will help much with condensation but maybe.
I love my windows too much to cover any of them permanently, but I need to be able to stop them from leaking massive amounts of heat, too.
01-09-2020, 05:37 PM
Chassis: GA39530
Engine: DT466E 215hp 620tq
Rated Cap: 40
Sewed up Curtains
I sewed up some insulating curtains, three layers and they roll up. Just an Idea. they call them Kume curtains.
01-09-2020, 05:44 PM
I noticed those in your build thread and they look very nice. What is the insulation part of them? Fingers crossed for aerogel ...
01-09-2020, 06:10 PM
Chassis: TC1000 HandyBus
Rated Cap: 26 foot
I'm thinking of using plexiglass, and cutting pieces the size of each window opening. Stick them in place (however they hold in place is another story) and they become double-pane windows for when it's cold. Still lets in sunlight, and you can see out, but reduces heat loss. Then the fabric-covered foam (as mentioned in previous posts) can also be used when it's dark and well below freezing.
01-09-2020, 06:36 PM
Chassis: GA39530
Rated Cap: 40
Its a three layer assembly. Polar fleece facing the window, polyethylene sheet next as a vapor barrier, then a medium weight cotton curtain material. made a big difference.
