Old 03-26-2019, 06:56 PM   #1
SamboDillyDally's Avatar
Year: 2008
Coachwork: Collins/Midbus
Chassis: Chevy E3500
Engine: 6.6L Duramax
Insulation with no floor studs
Hello, just wanting to see what people think, I read somewhere about someone who skipped framing their floor and just glued the insulation straight down and glued plywood ontop of that since plywood distributes weight really well and saved them some money. Is this viable? I like the idea and Foamular has 25PSI boards and thats what id be using.
SamboDillyDally is offline   Reply With Quote
Old 03-26-2019, 07:01 PM   #2
That's 25psi by itself, or 3.6 tons psf. And that goes up exponentially when you put plywood over it, so it's not an issue. I plan on 1/2 rigid, 1" rigid with PEX laid in and my snap together wood flooring right on top of that. All floating with no plywood. I'm sure there will be things secured through the floor at some point. I cut the insulation 1/8"-1/4" to long side to side so it is a snug fit and won't move.
Old 03-27-2019, 08:25 AM   #3
Year: 2008
Thats good news. I plan on gluing it down with loctite and the plywood over it with loctite to avoid any moving. Thank you
Old 03-27-2019, 09:04 AM   #4
Rovobay's Avatar
Rated Cap: 35
I put down 2 inch foam and then a thick sanded finished plywood (5/8" or so.) screwed the floor directly down into the floor beneath the foam.
My Build: https://www.skoolie.net/forums/f11/sk...doo-22140.html
Follow our build on Instagram at https://www.instagram.com/skoolie_doo/
Rovobay is offline   Reply With Quote
Old 03-27-2019, 09:16 AM   #5
Year: 2008
Doesn't this make a thermal bridge though? Or does the flooring over the plywood cover it pretty well?
Old 03-27-2019, 09:22 AM   #6
1.8 tons psf. Yay English measurements.
